Question about Admiral AW22 Top Load Washer
Admiral top loader no spin cycle
My Admiral washer will fill with water and agitate, but when it comes time to spin it wont drain or spin. I dont hear the motor or any other noise.
I opened the lid and put a screwdriver to press the switch to see if it will
spin nothing happened. Any ideas?
Is it normal when you open the lid the washer continues to agitate?
Thanks
  • 6 more comments
  • huet Mar 15, 2008
    Is there a way to troubleshoot the switch?
  • huet Mar 15, 2008
    Thanks
  • huet Mar 15, 2008
    Could it be there is three wires to the switch.
  • huet Mar 15, 2008
    I do not have it washer belongs to my mom.
    I only could get tomorrow.
  • huet Mar 15, 2008
    I will test first and the I might jump it.
    Problem is I only could try it tomorrow.
    I will print out all the suggestions and try them.
  • huet Mar 15, 2008
    I will contact you tomorrow. Thanks alot
  • Anonymous Mar 13, 2014
    How do I get the washer lid open when machine is filling up for rinse cycle? It locks.
  • Anonymous Mar 17, 2014
    My Admiral washer works perfect until it gets to the spin cycle.while opening the top door and inserting a screwdriver to the spring loaded switch I can see that it's trying to spin but when i put my hand on the unit with little to no pressure i'm able to stop it.from what i can see there are no belts on this washer that may be slipping.
    President:
  • 1,314 Answers
You can take an ohmmeter and remove one lead from the switch set your meter to continuity and see if it reads open then depress the switch and see if its closed or take both wires off the switch and put a jumper wire in the connectors to bypass the switch and see if it spins and yes its normal to keep agitating with the lid open the switch just works on spin
Posted on Mar 15, 2008
  • 1 more comment
  • robert samples Mar 15, 2008
    could be whats the model number off the serial plate ill see if i can pull up a wireing diragram
    are you testing with a meter or you going to jump it
    ok ill be here tommrow also if you need more help just let me know should be a tech sheet wireing diagram behind the control panel
  • 796 Answers
Check the drain pump first, its inside the bottom of the washer.
This link should help you locate it:
http://www.applianceaid.com/neptune.html (http://www.applianceaid.com/neptune.html)
  • isaac johny
    isaac johny Mar 15, 2008
    HI THERE ...NICK..
  • isaac johny
    NICE TO SEE YOU ARE BACK
  • 73 Answers
No i would cheak that switch out that u pushing down on mightbe bad try that 1st ok thx nick
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Jan 06, 2008 | Admiral AW22 Top Load Washer
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Admiral AW22 Top Load Washer Logo
429 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
