Error code H3 displayed on Xerox XC1044 Copier
I have a Xerox XC1044 Copier. Turned copier on yesterday and received Error Code H3. Copier will not operate and can't extinguish H3 error code. Appreciate any assiistance in resolving this condition.
Thanks,
Bill
  • Anonymous Jun 09, 2008
    Tenho o mesmo problema numa xerox xc 830 tem alguma forma de resolver esse problema ?
    Habit-Forming:
  • 96 Answers
This is the solution:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode' (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
To exit diagnostics: Press 'Clear' repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select '14' followed by 'Print'... exit diagnostics.
H3 stands for high temperature at the fuser.
Posted on Oct 10, 2017
SOURCE:
  • 2072 Answers
SOURCE: Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Posted on Jan 02, 2008
  • 8 Answers
SOURCE: Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Posted on Mar 04, 2008
  • 45 Answers
SOURCE: Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Posted on Mar 08, 2008
  • 1894 Answers
SOURCE: Canon copier Error Code 300 Model
Solution:
Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser.
Posted on Mar 13, 2008
  • 1894 Answers
SOURCE: Sharp AR-201 network printer /
have you reset the printer?
Posted on Mar 14, 2008
What does error code h3-00 indicate?
Sharp ARM 550/620/700 Reset Machine with Error Code ...
? 1:26
www.youtube.com/watch?v=BXs8PmMXFtk
May 5, 2011 - Uploaded by Thomas Trumpler hi thmas please tell me how to clear sharp mx-m620n copiermemory chip to use it ... How do I clear error code h3-00 on mysharp mx--453.
Sep 30, 2015 | Sharp DX-C401 Color Copier, Printer,...
Tip
Xerox XC and XD series copier H3 or H4 error code reset procedure
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
on Mar 20, 2010 | Office Equipment & Supplies
I believe the copier is not warming up as needed to. the code h3-01 appeared on the display screen i have cleared the code but it is taking alot of time to warm up as if its stuck trying to warm up. what...
H3-01 = High temperature detection.
Your copier is warming up ok but for some reason the correct temperature is not being sensed and the machine is detecting 'overheat' and switching off.
First, check that there is no paper stuck inside the fuser unit - it may be blocking the temperature sensor (thermistor).
Does the fuser unit feel warm after the error code is displayed?
Try resetting the code:
P,*,C,*,14,[copy button] ( P,STAR,C,STAR,14,COPY BUTTON)
The machine should reboot.
Hope this helps.
Jan 06, 2011 | Sharp AR-M350U Copier
I turn my xc1044 copier on and get a H3 code and machine will do nothing
You can try resetting the code. If it comes back then the machine will need service. The H3 code is a fuser code which is the part that gets hot right before the paper exits the machine.
Press the C key then the far left key then the C key then the far left key. So C,far left,C,far left
These 4 keys must be pressed within 4 seconds. If done correctly your display will go blank.
If so then key in 14 as if your were going to run 14 copies then press the print button.
This will reset the code, at least temporarily. The H codes sometimes pop up when there is no issue with the copier.
If it comes back you will need a repair person.
Good Luck and Thank You for using Fixya.
Mar 11, 2010 | Office Equipment & Supplies
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
I have a Xerox XC1020 copier with a code H3. What does this mean?
The H3 code is a fuser high temperature code.. First fix is to power down and let the machine cool down..
Failing that, I couldn't find a clearance method for that particular machine but most of the machines in this category had the same control panels for years so it might work.
This is for an XC811 machine, same family, so it might work. If any of the controls mentioned are not on your machine then you need to contact the helpdesk if it still exists or a local copier repair place who should know how to clear the codes.
"To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
H3 stands for high temperature at the fuser."
If it persists then you have a fuser fault that will probably need to be replaced.
And as I said, this is not specifically for your machine but the clearance codes for Xerox machines tend to be similar.
Good Luck!!
Oct 09, 2009 | Xerox Office Equipment & Supplies
Need repair manual for Xerox XC1044 copier
These manuals are usually only available to technicians in authorized dealerships. You might try ebay.
Jul 03, 2009 | Xerox Office Equipment & Supplies
Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Apr 11, 2009 | Sharp AR-407 Copier
Error Code 10-399
Hello sir; The problem you have can be reset, just follow the steps as below;
1, power on the machine.
2, while hold down the 0 key, press start.
3, enter the access number 6789
4, click onNVM reset/NVM initialization.
5, enter 777-018 press start.
if still have problem let me know
Jan 02, 2009 | Xerox DocuColor 12 Color Copier
How do ya reset fuser code (H-4) Xc1044 Xerox?
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Nov 26, 2008 | Xerox Office Equipment & Supplies
Open Questions:
Computers & Internet Logo
346 people viewed this question
Ekse
Alun Cox
