Question about Cyberhome CH-DVD 300 DVD Player
Display reads HOW DO I CORRECT THIS PROBLEM. THE ON SCREEN MESSAGE. "No Disk" Where is the eye or lens located? How do I access it? How do I clean it? Can you help me?
    Genius:
  • Cyberhome Master
  • 1,550 Answers
Compra un disco para limpiar laser e insertalo si con eso se soluciona que bueno.
Posted on Mar 25, 2008
Disc invalied
If you are getting this message with an pre-recorded commercial DVD and it is from the correct region for your country then there is a problem with the laser not reading the disk and this is usually due to dirt or debris on the lens.
However, it is worth noting that these Coby players commonly give disk read errors such as this due to faulty drive components.
To clean the lens, you can avoid disassembly of the unit by using a DVD cleaning disk such as this. The alternative is to clean the lens with a Q-Tip and some isopropyl alcohol but you may have to disassemble the unit to gain access to the laser.
If the problem is related to disks you have recorded yourself make sure that these have been finalised before playing them with the DVD player.
The spec for this player states that it widely supports all of types of disk including Audio CD|CD-R|CD-RW|DVD|DVD+R|DVD+RW|DVD-R|DVD-RW
Therefore the problem is not with the type of disk you are using but the player itself as outlined.
Hope this helps. Thanks for using FixYa.
Jan 03, 2010 | Coby DVD-233 DVD Player
Game not working ps2 slim
did you try cleaning the laser lens? q-tip + small amount of rubbing alcohol, then use other end of q-tip to dry it. or you could use a laser lens cleaner for video game systems. hope this helps :D
Mar 06, 2009 | Sony PlayStation 2 (PS2) Console
"No Disk" message on front display
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Dec 27, 2008 | Pioneer DV-343 DVD Player
How to do DVD burning which does not complete? Why it is not finishing ?
the laser eye lens is probably dirty and a cleaning disk may correct the problem but if not then the unit will have to be opend up and cleaned manually ( there are creases in the laser lens that the cleaning disk won't get , but manually can be cleaned
Oct 27, 2008 | Televison & Video
RIPED OFF BY BROADWAY PHOTO
Unit may have dust or contaminates built up on optical pickup. If you can reach the lens, try to very gently clean the pickup lens with a Q-tip. It is possible the unit has a defective turntable motor in which case you will have to have it replaced
Jul 31, 2008 | Video Cameras
PS2 configuration problem
This usually happens when the lens eye is dirty or has dust particles on. To clean use a Q-tip and dip the Q-tip in rubbing alcohol or water. You want the cotton to be just damp. Gently clean the lens eye with the cotton. Then use the other side of the Q-tip to dry the access rubbing alcohol or water. You then might want to clean the disk tray. hope this fixes ya problem.
Dec 31, 2007 | Sony PlayStation 2 (PS2) Console
Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Aug 31, 2007 | Daewoo DVDS151 DVD Player
When i put the dvd, in my screen it presents message 'no disk'
If you scratched the lens or even out a smudge on it, you might have ruined it. Use a Q-tip with nothing on it and gently swirl the lens for about a minute. Hrad to tell if it is just limited to the lens or to the foucus coil assemble as well without seeing it. Never attemot to clean the lens if you are not trained to. Use a CD/DVD lens cleaner if you need to clear a "no disc" error.
Apr 30, 2007 | Yamaha DVD-S700
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
