Question about Toshiba Satellite M45-S265 Notebook
Cmos password reset
I own a satelite m45 and one of my kids placed a cmos password on my laptop. i am a tech coordinator -
  • morbr Jun 26, 2008
    I have a Toshiba Satellite M45-S265. How do I get to the CMOS battery?
  • 91 Answers
Also you can try this method:
ReSetting Bios Password on Toshiba Satellite A135-S2386
1)Remove Laptop Battery
2)Take off Memory Cover(underneath - square cover, Sits in middle of laptop 1 retaining screw
3)Using two thumbs spread spring clips to outside and pull out RAM memory.
4)Remove clear vinyl label opposite RAM memory slots in upper left corner( laptop battery slot is on right, DVD drive is facing away from you)
5)Using a magnifying glass (unless you have perfect vision)in the upper left corner you will see JOPEN1 with a white silkscreen square next to it . Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4" post connecting the motherboard to the laptop case(this is your ground, it is located above what looks like a silkscreen outline of a chip)hold for 25 -30 seconds.
6) Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Now hit F10 key ,yes to save and your done!
Note: if your having trouble your most likely grounding the ground(that blob of solder about 1/8"dia on both ends of the "silkscreen chip outline" this is taken from this link:
http://www.hardwareanalysis.com/content/topic/18140/?o=40
there are also pictures there at the end of the page.
Posted on Mar 15, 2008
  • 655 Answers
Ok
plz goto my profile and see my all solutions i have given many times answer on this topic.
If you dun find tell me i will copy again for you.
And also tell me about your feed back.
Thanks
iqbal
SOURCE:
Toshiba satelite bios password recovery
On laptops there isn't an easy way to recover passwords in the BIOS. Sometimes you can reset the password. Other times, you'll have to contact the manufacturer to get it reset.
Some laptops will allow you to reset the BIOS password by pulling the CMOS battery. The CMOS battery is typically located under one of the bottom panels for access to the memory or wireless cards. Some models have the CMOS battery connected by a small wire with a clip connector, others have the CMOS battery placed directly on the motherboard with a metal retainer clip.
Here is a link to a removable CMOS battery with wires: http://www.laptopparts101.com/wp-content/uploads/2008/12/removable-cmos-battery-560x420.jpg
Here is a link to a CMOS battery that is directly on the motherboard: http://www.laptopparts101.com/wp-content/uploads/2008/12/coin-cmos-battery-560x420.jpg
On a laptop, if you unplug the power cord, remove the laptop main battery and then remove the CMOS battery - and then wait at least 5 minutes, some models will blank out the BIOS password. Not every BIOS password can be erased by removing the CMOS battery - but if you are comfortable working on the laptop parts it is worth a try.
If removing the CMOS battery doesn't fix the BIOS password, the only option left is to contact the manufacturer for a reset. (If you took your laptop to a certified technician - they would just contact the manufacturer for the reset, and then bill the time to you!)
The number to contact Toshiba is 1-800-457-7777.
Nov 19, 2011 | Toshiba Computers & Internet
Remove password the bios of toshiba m45-s169
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 28, 2010 | Toshiba Satellite M45-S165 Notebook
My kids setup a bios password on my new HP laptop and they cant remember it. How do i remove the password without knowing the previous that was set by them. Please guys help me.
The only way to do this is to reset the CMOS/BIOS memory.
  1. Remove the back cover of your laptop to "reveal" motherboard.
  2. Make a way so that you can see the a bigger portion of the motherboard ESPECIALLY the small lithium battery powering the CMOS chip.
  3. If this battery is reachable, remove it in place.
  4. After 3 minutes or more, place the battery back.
  5. Place the covers back and power on your laptop.
  6. The bios password now should be removed since the content of the CMOS memory is cleared.
Jun 06, 2010 | Computers & Internet
I am working on a toshiba satellite l355-s7915. the owner's kid forgot her password, so I tried to remove the password with hirens active password changer, which failed. when I started up the computer, it...
Yes of course all Laptop and Desktop have CMOS battery. Screw the back cover of your laptop locate the CMOS battery and remove to clear the BIOS password. Or else you can reset the CMOS by removing the jamper.
Mar 29, 2010 | Toshiba Satellite A135-S4527 Notebook
The laptop is dead.
It does sound like your cmos battery. It is located on your system board. If your confident you can take the laptop apart and get the details from the battery and then goto a pc shop and buy a new one if not take the laptop to the shop and they can replace it for you.
Feb 22, 2010 | Toshiba Satellite M45-S165 Notebook
Forgot password fot toshiba satellite m45-s169
Thats a Power On Password...I believe the only way that you can get around/reset/disable it...is by taking out the battery out of the Cmos. I will be looking for more ways other then that but thats one that i know works...
If you would like to attempt it...i dont recommend it for the no computer people...look up fourms and see if others have had the same problem or if people have taken the computer apart and replaced the cmos battery
Dec 12, 2009 | Toshiba Satellite M45-S165 Notebook
How can remove BIOS password
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 19, 2009 | Toshiba Satellite M45-S165 Notebook
Satellite m45 s265 keep asking for a password wont go pass bios screen plz help
temporary operate your laptop without the cmos battery. if you cant locate the cmos battery ask a person who knows.
Jul 06, 2009 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite M45-S265 reset cmos password
You can download the manual from here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Enter+Keyword%3AToshiba+Satellite+M45-S265&x=12&y=4
It should solve the problem, enter BIOS and change password by filling in only banks(spacebar)........sodeep
May 08, 2009 | Computers & Internet
Bios/startup password
yes, it will still be charged, to reset the bios password you need to locate the cmos battery on the motherboard and remove it for 10 mins or so, but where exactly the battery is situated, i'm not sure.
Apr 17, 2007 | Toshiba Satellite M45-S265 Notebook
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
202 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
