i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Try resetting you're bios...other than that, try replacing the connector (not out of the realm of possibilities it could be bad or not seated properly.) Try plugging it into another connector. Chances are, resetting the bios will probably do the trick. Other than that, the drive may be bad.
Check the SATA/RAID controller setting.
It could have been set to [Disabled]
Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings.
Regards
SparkGap
