Question about SanDisk Sansa e260 MP3 Player
Sandisk e260 sandisk/rapsody screen is blinking on and off. it will shut off after holding the power/menu button for 30 seconds but thats all she wrote.
  • Raini Day Apr 09, 2008
    When I press the power button, it comes on, Shows the SanDisk logo, then says, "key locked" "system shutdown". What do I do?
The screen is locked
Posted on Mar 29, 2008
SOURCE:
When i turn on my sansa e260 and show the sandisk logo, it restart showing the logo over and over without going to the main menu, how do i fix it ?
Hi, welcome to fixya!
You need to reset your sansa for it to be in order again.
Learn how to reset the your various San Disk models;
Resetting a Sansa Fuze+, Clip+, c200, e200, or e200R player:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Resetting a Sansa Express player:
NOTE: The device can be either ON of OFF.
1. Press-and-hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
2. Release the buttons.
If resetting doesn't solve the problem, please let me know for more assistance.
Good luck.
Nov 03, 2011 | SanDisk Sansa e260 MP3 Player
I can't reset my sansa mp3 e260
To reset sansa
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for20 seconds.
May 28, 2011 | SanDisk Sansa e260 MP3 Player
Frozen screen
When the Sansa e260 is frozen, first try to reset the player.
How to reset the e200 series player:
When resetting does not solve the problem, a reinstallation of the
firmware should be performed.
Need more help ? Just post a comment.
Dec 24, 2009 | SanDisk Sansa e260 MP3 Player
My sandisk sansa e260 mp3 player is always freezing . when i turn it on it pops out a window that says "refreshing database" . then stops and only load 15% of it .
As you may have noticed already, the player can be switched off when freezing and put on again, resetting the device as next:
Sometimes a firmware update or reinstallation is required, to get the player function normally again, see:
http://kb.sandisk.com/app/answers/detail/a_id/306
Dec 03, 2009 | SanDisk Sansa e260 MP3 Player
My sansa fuze 4gb is frozen on the connected screen
hold down the power and menu button for 30 seconds and it should restart it
Dec 11, 2008 | SanDisk Sansa e260 MP3 Player
Battery is too low. System shut down
Have you tried removing and replacing your battery? What about the connections and cord, are they damaged at all?
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 05, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 screen stays black at power up.
Have you tried holding the menu button down for 30 seconds to reset the devise?
Oct 31, 2007 | SanDisk Sansa e200 MP3 Player
E270 - white across top of screen - menu won't come up
Hey scoob, I have 3 of these players in my home and every time there is a problem with them we find that if we HOLD the power button in and keep it in until it shuts off (while the button is still pressed)... can take a full minute or more, it seems to reset any problems we have encountered. worth a try
Jun 10, 2007 | SanDisk Sansa e260 MP3 Player
WON'T TURN ON
I just got an e260 today and had the same problem. When I originally turned it on the Hold was in the 'locked' position. From there on out the screen has been black. When it was plugged in nothing happened either. The Solution? Hold the power button for about 20 or so seconds. The manual doesn't tell you about it, but that's how you completely shut the sansa down altogether. Yes, the manual says it's also a reset button but it isn't mentioned how you actually use it. Once you hold that button down long enough it should completely shut down and restart.
Dec 03, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
