Question about Miele CVA615 Espresso Machine
BrewUnit Blocked Error
I already tried the other solutions, grinder reset, cleaning, lubricating, but the Brewunit Block error is still there. I can remove the brew unit without any problem and I can move the mechanism up and out of the funnel and into reset. I can fully move through all the positions. It looks very clean, but still a fault. I hope you have a solution.
  • nervos Jun 08, 2008
    I've tried and tried but the message is still the same BREWUNIT BLOCKED tho I can't find what could be causing the problem I have cleaned it and jogged all the moving parts with no success replaced it all in the unit a dozen times and it just won't start or make any noise like when it self tests
  • Simon Maddox Apr 24, 2013
    Mine has just started doing the same. I've cleaned the stainless steel filters in the brew unit, but no joy. It sounds like the pump is not working properly - I'll have a look when I get a moment and let you know.
  • 4 Answers
The brew unit sensor may have become disconnected from the main circuit board. If you are very brave, you can UNPLUG THE UNIT, remove the top panel and check that all the wires running into the circuit board are connected.
Otherwise, the sensor may have failed and this will require service.
Posted on May 05, 2008
The brew group is stuck and won't come out.What to do?
Hi. Its not an easy fix. The brewunit is stuck in cycle, with the injector pipe holding it in. The injector pipe is at the back behind the brewunit. You just need to use force by wriggling and jiggling the brewunit. There maybe some screws in the brewunit, that may help you if you undo them. If you do get the unit out, then you have to work out WHY it has not completed the cycle, so when you put the unit back in, that is not going to get stuck again. Ive spent 30 mins getting out a unit, only for it to get stuck again. For some reason, its easier to get the brewunit back out the second, or third time you try it.Sometimes you may have to break something to get it out. Id recomend taking it to a repairer and let them work it out. It can take hours of work and care must be taken, not to do too much damage. Even disassembly and reassembly or the outer panels canbe a challenge on these models. Saeco are a good machine, but are a dumb design when ti comes to stuck brew units. Sorry I cant be more help with this problem, but I hope its just a soiled brewunit, and once you've removed and cleaned it, It'll work fine again. Weekly cleaning tablet should stop it from happening again. Dazza
Oct 21, 2011 | Saeco Odea Giro Plus Coffee Maker
Brew unit stuck
Hi molly girl.
You can try to clean your Brewunit. Most of the times when that message appears, it means the brewunit is dirty
You can have more info in the manual if you dont have it:
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
Jan 11, 2008 | Miele CVA615 Espresso Machine
No matter what I do the Gaggia Titanium espresso machine reads brewunit missing;. This is what I did: I removed the brewunit of the machine to clean it, and reset the N to the correct position on the front...
HI
If the brew unit is in the wrong position when inserted you can knock the lever off the microswitch in the back. If the lever is knocked off you will never get the brw unit miss message to go away. You will have to take the machine apart and replace the lever on the microswitch. Sorry
We made a modification to the brew unit that would prevent this from happening. We modified all the brew units on the compact machines before sending them out so we would never get them back for this reason.
Apr 26, 2011 | Gaggia Titanium Espresso Machine
Hi i have lost pressure on the steam spout i changed the 3 rubber seals but still no better also water comes out of the steamer
Hello, my brewunit make a rackett when I turn it on ... then stops and says 'brewunit blocked ... anyone got any ideas ...
Aug 27, 2010 | Miele CVA615 Espresso Machine
Saeco odea giro is not grinding enough coffee.. the pad is like half or less than that.. it seems like a pcv problem .. HOw can I reset or reprogram to grind more coffee?
Hi,..These saeco models have a auto adjusting grinder. If the brewunit is heavy or in other words overloading, the machine will reduce the grinding time lesser to produce less ground coffee.If it senses the brewunit is smooth and light in loading (compressing the grounds), it will increase the grinding until it reaches the optimum dose. So it is important to clean and lubricate the brew unit at all times. Hope it will solve the problem. Good luck.
Jun 18, 2010 | Saeco Odea-Giro Espresso Machine
Gaggia Titanium, "Brewunit Blocked"
Check the shower screen in the unit it is possible that it is blocked with coffee oils.
Aug 03, 2009 | Saeco Incanto Classic Espresso Machine
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hi I have a gaggia titanium coffee machine it has comme up with an error message the the brewunit is blocked i have decalcified machine but no joy can you help
Remove brew unit, If you have the key that came with the machine use it to remove the shower screens and check for blockage.
Mar 29, 2009 | Gaggia Titanium Espresso Machine
Brew unit blocked
You can remove the brew group by following the "how to remove a jammed brew group?" on this page http://cerinicoffee.com/Saeco_technical_documents.asp
For Cleaning Supplies and Saeco Parts visit:
www.cerinicoffee.com
May 30, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Brewunit block
kristijordan,
I had this error message on my machine and was able to take care of it by lubricating the brew unit with silicone. I small tube of silicone grease should have come with your machine. If not I found silicone grease at Aco Hardware (not in a tube) and applied it using a toothpick. Machine has been working great since.
Winesnob
Sep 10, 2007 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
1,032 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
