Question about Alpine Air XL-15 Air Purifier
Not ionizing I have owned my xl-15 for a few years and its ionzing has just been slowly getting worse and worse I have it turned all the way up and can barley here it zapping the air anymore. Any thoughts.
Ozone plates need to be cleaned periodically. I use non-sudsing ammonia in a flat pladtic container big enough to let the plate lie flat in an 1: of ammonia. I let it soak for a few minutes (do this OUTSIDE due to the ammonia fumes) then scrub both sides of the plates with an old toothbrush. When done I rinse it under the sink, along with the bowl and brush (windows open). Let it fry thoroughly before reinserting in the machine (slide carefully in track and gently hold contacts aside with fingers so it slips in easily to avoid cracking the plate).
- Robert
Posted on Apr 18, 2008
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
Red light will not go off
The only other light I'm aware of is the light in the back of the machine attached to the radio frequency ionizer. This light lets you know that both of the ionizers including the needle point ionizer are working. When the light is off, it means the ionizers need cleaning or service. When I clean my machines, I always clean off both ionizers w/ a 50/50 solution of Ammonia w/ a paper towel. I do this the same time I clean the ozone plate. If you're machine is still under the 3 year warranty, you can send it back to be fixed for no charge except shipping. I hope this helps.
Jul 25, 2011 | Alpine Air XL-15 Air Purifier
I have the Alpine Living Air machine - the green light does not come on just the amber one. I don't smell any ozone odor. Cleaned the plates but not sure if they have to be installed in any special...
How long have you owned machine? Plates need to be replaced periodically to be effective and to generate ozone. Depends on usage but at least every one-two years. They run about $15 a piece. I can get you some.
Jul 07, 2011 | Alpine Air XL-15 Air Purifier
I have an Alpine ZL-3 and we can't smell the ozone any more. Our air doesn't smell fresh any more. My husband has been cleaning the ozone plate with warm water. Does this have anything to do...
OK- The plate needs brushing with a bristle brush to get the oxidized crystals and grime off it. If you don't, it will not create ozone. I never use water any more, it rusts the plate eventually. Rust also stops the process. I use rubbing alcohol. Cheap and safer than ammonia...MUCH safer. Blow dry. The only bulb is the radio wave ionization indicator bulb, attached to the round antenna-looking thing. You should wipe the ionizers off with alcohol every 6 months too. If they are gunked up they don't work nearly as well. Look up the Living Air Classic manual.
May 25, 2011 | Alpine Air XL-15 Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
I have a Living Air XL-15 purifier which was taken apart for cleaning and repair. I am now trying to put it back together and have one part that I do not remember where it goes. It is a metal needle-like...
That's a needle-point ionizer, should thread into a little arm/fitting in the fairing forward/front of the fan blades. The red wire (high voltage) should attach to this little arm (probably with a spade terminal). It provides the high-power ionization used to attract particulate air pollutants out of the air.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Nov 10, 2009 | Alpine Air XL-15 Air Purifier
XL-15 Classic Living Air emmitting Foul Odor!!
Ionizers do cause a bad odor to happen. I work in the copier business and do work around machines that can cause an ozone to happen when there are ran. Copiers like ionizers can cause an ozone to happen because the air particles are being electrically charged. The smell isn't good to be breathing in as well.
Here is an EPA report about ionizers
The Consumer Products Safety Commission is going to be making a decision about the health effects on ionizers by the end of the year. Their decision can effect selling ionizers all together.
This industry should have been regulated years ago and after what happened to Sharper Image this year due to their arrogance it isn't doing the industry any favors. They went out of business because of Consumer Reports findings and tried to sue them for it.
If you really want the air in your house cleaned, the best way to do it is using a hepa filter.
Jul 26, 2008 | Ecoquest Living Air Classic Air Purifier
Class action lawsuit
Not only that but even the EPA has said that ionizers are bad for filtering the air to begin with and that the report has been out there for several years.
Here it is from the EPA
The Consumer Product Safety Commission is going to make a report on all ionizers by the end of the year. It is possible that they will no longer be sold in the US forcing others such as Orcek into some financial trouble.
Jul 26, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
No lights no fan on Alpine Air XL-15
Use a DVM continuity function to see if the fuse is blown, and check all the DO FIRST literature packed with the thing. You probably get to take a note out of the ionizer chamber.
May 13, 2008 | Alpine Air XL-15 Air Purifier
Alpine Air XL-15 Air Purifier Logo
99 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
