The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
