Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
My sound i was trying to delete all my stuff that i dont really use and i think i had deleted my speaker icon for my volume there is no sound at all please help
    Guru:
  • 377 Answers
Hi dear
Through the All Programs menu:
1.
Click Start.
2.
Point to All Programs.
3.
Point to Accessories.
4.
Point to System Tools.
5.
Click System Restore.
6.
Follow the instructions on the wizard.
Creating a restore point can be useful any time you anticipate making changes to your computer that are risky or might make your computer unstable. If something goes wrong, you select the restore point you just created and Windows XP undoes any system changes made since that time.
Create a Restore Point
1.
Open System Restore. (See step-by-step instructions above.)
2.
Click Create a restore point, and then click Next.
3.
In the Restore point description box, type a name to identify this restore point as seen in Figure 1 below. System Restore automatically adds the date and time that this Restore Point is created.
Figure 1. Creating a restore point
• To finish creating this restore point, click Create.
• To cancel restore point creation and return to the Welcome to System Restore screen, click Back.
• To cancel restore point creation and exit the System Restore Wizard, click Cancel.
To view or to return to this restore point, from the Welcome to System Restore screen of the System Restore Wizard select Restore my computer to an earlier time. Then select the date you created the restore point from the calendar in the Select a Restore Point screen. All of the restore points you created and you computer created on the selected date are listed by name in the list box to the right of the calendar.
Note System Restore does not replace the process of uninstalling a program. To completely remove the files installed by a program, you must remove the program using Add or Remove Programs in Control Panel or the program's own uninstall program. To open Add or Remove Programs, click Start, click Control Panel, and then click Add or Remove Programs.
oke
cropp
Posted on Mar 25, 2008
6ya staff
SOURCE:
How do i remove the volume icon from keep popping up onto screen
when the volume icon is pops onto your screen right click on it select delete also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Apr 11, 2011 | Computers & Internet
No volume on my computer
All you say is there is no volume. I will have to assume that the sound card is actually "seen" by the system. If it is in the device manager and it is shown as working, there are three things that can be wrong: Your volume can be turned really low. The speakers can be muted (will show up as muted in the sound setup in the control panel). The speakers can be bad. Unfortunately, this will require dissassembly of the computer.
Check the easy stuff first. Also, check the sound jack on the side of the computer with either external speakers or a headset. If you have checked everything else and the headset works, then the speakers are bad or disconnected.
Sep 26, 2010 | Computers & Internet
I accidentally delete or lost the Speaker icon next to the clock at the bottom of my computer and cannot get any sounds from the computer whatsoever.please assist. Thank you.
You will want to go to control panel and go to sounds, if you go through the tabs (probably the first) there will be a check box that says 'show sound icon on system tray' enable this and whala.
Jun 25, 2010 | Computers & Internet
I have a dell computer that runs windows xp. im not a complete idiot but im not very computer savvy. I was messing around a few weeks ago trying to clean up my system from the previuos owners stuff . i...
Many Dell PCs have an internal speaker that will allow sounds and even music to play - it is just not as good as the external types that offer sub woofers and stereo sound. As long as you're hearing the familiar Windows Sounds and not simple beeps - your sound card drivers are probably ok.
This makes me think that you've either inserted the speaker plug into the wrong jack on the PC or have an issue with the speakers themselves. Generally, these jacks are color coded. If yours are, make sure that speakers are connected to the GREEN jack. If not color coded there should be an indication of an arrow pointing OUT or a speaker icon near the speaker jack. If still no luck, it is possible that the cord between the plug and the speakers has gotten pinched or broken. Try plugging a pair oh head phones into the jack - or plug the speakers into another device with a speaker jack. I'm pretty sure you'll get your answer after doing that. Some final thoughts: Maybe your speakers need power? Are they plugged in? Is the outlet powered? Is there a power indicator? Is the volume knob turned to minimum?
If you still have problems - provide the model number of your Dell PC and we can dig some more - but I think you'll find the problem if you follow the steps above.
I hope this was Very Helpful - and good luck!
Mar 15, 2010 | Computers & Internet
Ive deleted sound on my computer. wat do i need to do? no sound found
Hi peewee,
I'm not entirely sure what you mean by deleted sound.  I'll run some questions by you to clarify.
Have you: -checked to see that all of your speaker cables are plugged in correctly and that your speakers are functioning properly -have you checked to see that everything is turned on and has power running to it -are you running XP/Vista/Linux/OSx? -have you recently installed any audio codecs or soundcard drivers? -if you go to your startbar, and look at the speaker icon in the bottom right corner, right click and select open volume controls, check to see if anything is muted or has the volume down
Hope that helps.
Mar 12, 2009 | Computers & Internet
My harman/kardon speakers dont work
I was listening and the next minute the sound is gone. I no longer have the little 'speaker' icon on the lower right of my computer for volume control. How do I fix this?
Jun 17, 2008 | Harman Kardon HK206 Computer Speakers
Computer Sound
ok..go to control panel from start button, settings, and select sound icon..at bottom you can re add that icon to your taskbar..
May 28, 2008 | Gateway GT5032 (827103078121) PC Desktop
I want my music back!
Have you tried to raise the volume by double clicking on the speaker icon on your taskbar. This will open the play control panel where you can raise the volume.
If you do not see the speaker icon, go into your control panel and chose sounds and audio devices and raise the volume from that screen.
Mar 31, 2008 | Gateway 2520915 Keyboard
Acer speakers no sound
Hello!
You should tell the model of your acer or the sound card on it so that i can serach it for you. However you can search it by your own by simply going to the acer website and then search the model of your laptop and the go to the support and downloads.
http://www.acer.com.ph/ or selet your location and search your model.
may this help. melnavz
Mar 14, 2008 | Acer (90.18612.36B) Computer Speakers
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
