Question about Fine Digital FineDrive 400 GPS Receiver
Map data can u send me the map data files plz and install sd if u have it thnx.
    Problem Solver:
  • 4 Answers
Ok So I now have these 2 files on my pc, virus free. One is the Map_SD and one is the Install_SD. I unzipped them to folders of the same name.
Can I simply copy and paste both folders into a 1gb sd card and it will work ( I have to buy an sd card so Id like to make sure)
Thanks
Posted on Mar 28, 2008
    Scholar:
  • 107 Answers
As finedrive is not supporting their customers, I posted these files for download, the links should still work.
http://www.flyupload.com/?fid=951808
install data
http://www.flyupload.com/?fid=6960824
and the map data
http://www.flyupload.com/?fid=9768281
Posted on Mar 24, 2008
SOURCE:
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
Garmin Maps
No, Garmin maps will not work on a Magellan Triton.
Yes, you can install Bluechart and CityNavigator onto one SD card. Inside Mapsource, select the Bluechart maps you want, then switch to CityNavigator and select the maps you want from then, and then send all at once to the GPS unit. If you send Bluechart maps, and then CityNavigator, the CityNavigator will overwrite the Bluecharts. This is why it must be done all in one step.
If this solves your question, please remember to come back and rate the answer.
Apr 21, 2009 | Garmin GPSMAP 76Cx GPS Receiver
Frozen map screen
Try purchasing a new SD memory card (brand name) and installing the files there. Sometimes the manufacture sends cheap SD cards and the data is easily lost in damaged or poorly made SD cards. I have a EVESHAM 2007 and installed the files from the original CDto a new SD card and solved freezing and other problems resulting from poor data transmission from the cheap SD.
Also, try going online to the manufactureer's web site to see if they have downloads/ updates available there to replace the origianl install files that came with the unit. Always put on new brand new SD card.
Hope this helps
Feb 23, 2009 | GPS
Finedrive 400 Install instructions
files are too big to email or post:
one solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
The other solution was to send it to Fine Digital but they closed their doors in the US so they no longer support us customers. Because of this I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only.
Dec 28, 2008 | Fine Digital FineDrive 400 GPS Receiver
NAV CAM 2007 (GPS) NEW MAPS
Here is some other soft for your evesham device: http://www.driveway.com/NF98ogAJWR
http://www.driveway.com/i1EvQzR8FL
http://www.driveway.com/G3N0Y5jQ4s
When you finish the downloads, you need to unzip all the files, then copy the map files into the maps folder. Once this is done, copy the entire thig to the SD card and enjoy!
Dec 20, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Can not download map data for fatal application error
One solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
Nov 04, 2008 | Fine Digital FineDrive 400 GPS Receiver
Pop up screen
Do you have an sd card installed with mapping data on it ( a folder named garmin)? Or a defective sd card?
I had this error with a copied map, seems to be an issue with a wrong or missing *.unl file, which is an unlock file for unlocking map data
Jun 07, 2008 | Garmin zumo 550 GPS Receiver
Finedrive 400 Maps & data card
Thanks
Mar 22, 2008 | Fine Digital FineDrive 400 GPS Receiver
FineDrive 400: Original SD card got corrupted!
you need to reload the firmware in the unit and reload the map data on the SD card, this will fix your issues. as finedrive is not around anymore, here are the files:
here is the link to the instructions and install data.
install data
and the map data
Feb 14, 2008 | Fine Digital FineDrive 400 GPS Receiver
Open Questions:
Fine Digital FineDrive 400 GPS Receiver Logo
Top Fine Digital GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
