Question about Linksys Wireless-G WRT54GS Router (e125894)
Wireless connection issue
I am only able to connect to the internet if i click on connect to my isp. my wireless connections are not working at all
  • 1 more comment
  • pamconnor Mar 28, 2008
    i have done every thing step by step to install my linksys wireless router which is not working since I had to re-install my window XP. The router is fine but I cannot get it to work with my wireless card. How do I re-install the router?
  • Anonymous May 11, 2010
    Did you make sure the the suction labeles "wireless" is enabled.
    Hi, I'm on vacaton this week so it will tough to try to help you. Just so you know, I don't get paid for this, it's just been a hobby of sorts. I think you might want to look for someone else to help if you need assistance immediately...sorry.
    Novelist:
  • 141 Answers
How do you have the connection hooked up?
I have this router and this is my connection.
Computer #1
Wired -- in other words Modem--Router--Computer
My others are wireless.
If your hookup is the same when you run the disk you are given the option to hook up more computers wirelessly.
Choose that option
Then choose, flash drive
It will load the software onto the flashdrive and then you put the flashdrive in the other computers and click the folder (Vista, should pop up when flash drive is inserted) run the software and your computers should connect with no problem. I have 3 with internal wireless cards, 1 is WiFi and I had no problem, 2 others have external cards and I just put the codes the router gave me in my initial hookup and they connected no problem.
Any other concerns, contact me
Posted on Mar 27, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 15 Answers
What is the firmware on the router?
To check the latest list of firmwares click here.
For instructions on upgrading the firmware, click here.
Hope that helps.
SOURCE:
Netgear wpn824 v2 loses connection The internet light blinks amber every few minutes and I lose connection to the internet.
if you're online and loses connection every couple of minutes,that most likely be and issue with you ISP. it's intermittent connection issue with the server or might be the modem if it's more than a year.. better is to contact your ISP to check on their end,also to create a work order to investigate and monitor the issue.
Oct 07, 2011 | NetGear RangeMax WPN824 Wireless Router...
How do I set this router up with AT&T Internet?
Hi Friend,
Make sure that you have connected all the wires/cables to their respective ports/places. Please follow the steps:
1.Open web browser and type 192.168.1.1 and hit enter.
2.Enter admin as username and password.
3.Select the proper region.
For cable modem:
* For most cable modem users, you should be able to connect to the Internet without any
configuration. If your ISP has provided you with a host name, enter it in the optional Host
Name field.
* If your ISP requires a registered MAC Address, click on the Clone MAC Address button.
Click Apply and OK to save the setting.
* Go to Status tab, Internet connection section to verify if you get the valid IP address
information.
For DSL:
* Select PPPoE from the drop-down menu.
* Enter your username and password provided by your ISP.
Click Apply and OK to save the setting. Go to Status tab, Internet connection section to verify if you get the valid IP address information.
4.Click Wirless (to configure wireless settings).
SSID: Any name as per your choice.
Operating Mode: Infrastructure
Authentication: Open System
Channel #: 6
WEP: Enabled and type any ten digit number as your password. You can use this password whenever you try to connect your wireless devices.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 08, 2010 | Airlink AR430W Wireless Router
What do I do to have my wireless working away from my Internet connection and wireless Router. I have 2 Ethernet cables one going from my router to my Laptop and one going from my Router to my Internet...
Ok. As per your statement your laptop is working perfectly , when you are connected your laptop with with the cable wire.So the network cable is OK. So you have to configured the wireless cable in your laptop when it is connected to your laptop. After connecting the cable wire to your laptop you have to findout the gate way of your ISP ( Internet Service Provider). To find out the gate way , kindly follow the following instructions.
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ).To find out the above mentionedaddresses first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of your ISP will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly. Provided , that you have to configure the wireless enabling for both the ethernet cables and there after save the changes , after finding the 'GATEWAYS' if both the the ISP's seperately.
Oct 03, 2010 | D-Link DI 514 Wireless Router (DI-514)
Having problems connecting my lap top to my wireless cable modem. Its a motorola SBG900 gateway. everything seems to be connected. Im able to use it with a ethernet cable just need help geting it to be...
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of Motorola SURFboard SBG900 Wireless Router will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly.
Oct 03, 2010 | Arris SURFboard SBG900 Wireless Router...
I just brought a dell 10' netbook and i have dial up phone service so how can i get the internet on my netbook with dial up service?
Here is the internet setup info for that netbook from Dell's website ...
Setting up Your Internet Connection To connect to the Internet, you need a modem or network connection and an Internet Service provider (ISP).
To set up an Internet connection with a provided ISP desktop shortcut:
  1. Save and close any open files, and exit any open programs.
  2. Double-click the ISP icon on the Microsoft® Windows® desktop.
  3. Follow the instructions on the screen to complete the setup.
note.gif NOTE: Have your ISP information ready. If you do not have an ISP, the Connect to the Internet wizard can help you obtain one.
If you do not have an ISP icon on your desktop or if you want to set up an Internet connection with a different ISP:
Windows Vista®
  2. Click Start interne3.jpg ® Control Panel® Network and Internet.
  3. Under Network and Sharing Center, click Connect to the Internet.
The Connect to the Internet window appears.
  1. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect:
    • Choose Broadband if you will use a DSL modem, cable TV modem, or satellite modem.
    • Choose Wireless if you will use a wireless connection through a WLAN card.
    • Choose Dial-up if you will use a dial-up modem or ISDN (Integrated Services Digital Network).
note.gif NOTE: If you do not know which type of connection to select, click Help me choose or contact your ISP.
  1. Follow the instructions on the screen and use the setup information provided by your ISP to complete the setup.
Windows® XP
  2. Click Start interne6.jpg ® Control Panel® Network and Internet Connections.
  3. Click Set up or change your Internet connection.
  4. Click Setup. New Connection Wizard window appears.
  5. Click Next. Choose Connect to the Internet and click Next.
  6. Click Set up my connection manually and click Next.
  7. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect.
And here is the link to where the info was found...
http://support.dell.com/support/edocs/systems/xlob/dtg/en/internea.htm#wp1012333
and another with more info on that netbook ..
http://support.dell.com/support/edocs/systems/xlob/dtg/en/index.htm
Apr 06, 2010 | Dell Inspiron Mini 10v Netbook Computer
Trying to connect Belkin G wireless router to mac
No Issues at all !!!
As I Dont know who your ISP is , before starting the installation collect these information
1 : The connection Type
2 : If it is PPPoE then the user name and Password
Step 1 : Connect router - Computer ( Wired )
Step 2 : Open RSP By Typing 192.168.2.1 on the address bar of safari
Step 3 : On the left side click Connection type under Internet WAN
Step 4 : Leave the password Blank and click submit
Step 5 : Choose the connection type As per your ISP
Step 6 : Click next
Step 7 : On this page Enter the Information that has been given by the ISP
Step 8 : Click Apply Changes
Step 9 : Check What is the Internet Status on the Top Right hand Side
Step 10 : If it Is Connected then you will have Internet
Step 11 : If it is No Connection then
Step 12 : Unplug the Power Cable from the Modem And the Router
Step 13 : Plug the Power Cable back to the Modem
And wait until All the Lights Are Back
Step 14 : After all the Lights Are ON in the Modem
Then Plug the Power Cable back to the Router
Step 15 : Check The internet Status
Step 16 : If it is not working then
CALL : 1800-223-5546
Jan 03, 2010 | Belkin Computers & Internet
2 wire gateway..trying to go wireless....shows excellent signal but limited or no connectivity.
1. Try to determine whether you can connect to the Internet
Start -> Control Panel -> Network and Internet Connection
-> Network Connections -> Right Click Local Area Connection
-> Properties -> Internet Protocol (TCP/IP) ->
Use the following IP Address,
IP Address: 192.168.0.2,
Subnet Mask:255.255.255.0,
Gateway: 192.168.0.1
2. Reset modem and rebooted the computer
3. Check cables if they are properly installed unplug and replug
4. If issue where not resolve contact your ISP service to check if it's the connection or hardware issue " ISP service has a tool that can run a line test determining where the broken connection is."
Nov 15, 2009 | 2wire (1000-000057-000) Modem
Can not connect to the internet
check your firewall setting.
check if your connection is working or not, by connecting to other pc if possible.
check if dns etc config for your internet is ok, for this you must call you ISP and check if there are no issues with you connection.
showing connecting cant mean actually connected, it wont work unless confuguration setting are good.
Mar 12, 2009 | Computers & Internet
Draytek Vigor 2600we
I do not have one of these devices however from the specs it is a combination DSL modem / Router that supports both wired connections to 4 ethernet ports as well as wireless connections. This device has configuration options that apply to the ISP side as well as the wireless side that could be causing issues. Lets try eliminating the wireless issues first. Do you have a computer with an ethernet port for a wired connection. If so attempt to connect to the internet using a wire to the ports on the wireless router. If this works we are assured the ISP connections and configuration are correct. If not I would suggest working with your ISP to get this working first. If this does work the next step will be to review the wireless configuration. If you got this new or from your ISP these settings may be known. However if you bought this used we may have some discovery to make this work. However we can address that after we determine the solution to the above issues.
Dec 01, 2007 | Draytek Vigor 2600We (Vigor2600WE)...
Linksys Wireless-G WRT54GS Router (e125894) Logo
65 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
