Question about Vacuums
Replacement wand for canister
I have a Eureka Oxygen vacuum model 6996 type A. The electrical cable for the lower wand has partially melted the connector that joins to the beater unit. the simplist fix and cheapest would be to replace just the cable as the wand is fine. the second solution would be to find a lower straight wand that does not have the "sensor" (a dumb gimmick) but I don't know if it would fit. The last idea is to get the overpriced wand with the sensor.
Ultimately, it would be nice to know why the melting happened in the first place. It did happen when the vacuum was new, then the top connector melted and the wand was replaced under warranty. This second malfunction took years to happen. The prong that seemed to overheat looks rusty. I'm wondering if the electricity was somehow impeded there and caused a heat buildup.
anyhow, love anyone's thoughts on this.
    President:
  • 1,673 Answers
Whne you had your first problem with it, the cord at the bottom probably should have replaced also, if one end gets scrotched, the other end does also. One big reason why this happens is connecting and dis-connecting the power head while power is still applied to it. When you hook your skillet and it is turned on, it will arc, so does the contacts on the hose and power head. That prong is rusty, it is scrotched. Don't know if you can substitude, you might try to find a shop that has other wands and see if you can find a fit, either that or buy the one that is supposed to be with it.
Posted on Mar 15, 2008
Canister vacuum Sears model 116.59229210. The suction is coming through the vac for the hardwood floor setting, but the light on the power head will not work and the roller is not turning. I have...
Kenmore canisters are famous for melting the connection between the hose handle and the upper wand. They also sometimes melt between the lower wand and the power nozzle neck. Take it to your local vacuum repair center and get a diagnosis.
Dec 19, 2014 | Vacuums
Will not turn on
try plugging it in... lol just joking.
if you can open it up and see if the power cable is disconected.
Jan 25, 2011 | Eureka Oxygen 6996 Bagged Canister Vacuum
How do i replace the electrical cord for a Eureka 6996 type A The existing one will not rewind
Does the machine still run OK?
and the cord is not broken or badly kinked in any place
If so-- then maybe just the re-wind mechanism needs replacing.
This is going to require opening up the machine, and getting deep inside for repairs.
are yo equipped with the tools and patience to tear into the depths of this machine?
Another thought to consider:
The repair parts will likely cost close to $50-- is the machine about ready to fail in other areas?
How are the hoses?-- does it have necessary suction for your work? How old is the machine?
It might be good for you to take the machine to a Vacuum cleaner repair guy that you trust, and ask his honest opinion.
Jan 15, 2011 | Eureka Oxygen 6996 Bagged Canister Vacuum
My wand on my canister began to spark and snap and smoke. The element was melting. and now I am stuck with only a working canister. the elememt or electrical hook up is burned up...and I guess I am gonna...
How's the hose?
If it's only one wand, yes, you'll need to buy a new one. It depends on where it burnt out. If it was at a connection to the hose, the other wand, or the power nozzle, you need to check the connections thoroughly for discoloration, breaks/cracks, and potentially shorts in the hose, wand, and power nozzle.
The entire vacuum should be taken to the nearest Aerus Electrolux dealer for troubleshooting for what caused the sparking in the first place.
http://www.aerushome.com/storelocator/
Jan 09, 2011 | Electrolux Lux 5500 Canister Vacuum
Carpet rollers dont work
Hi There,
Yes, there is a reset switch on your Electrolux. This particular model also has some problems with the wands on the machine as well. Sometimes these wands will short out, preventing the power nozzle from working.
Try pushing the reset switch first to see if this fixes your problem. The reset switch is located on the power nozzle on the right hand side if you're looking down on it. It will be a little red pole, simply push this pole downwards, possible using a ball point pen is the easiest way.
If this didn't fix your problem, then it could be a few different things. The wands on your model are problematic, and should be the next thing that you test. Simply remove the wands from the power nozzle, and you can use a simply electrical tester purchased from Home Depot, and put the testers into the female receptacles on the end of each section of wand to ensure that power is getting down to the brush.
It may also be that your hose has gone bad. If you test both wand sections, and no power is getting through, remove both wand sections and test the female electrical connections on the end of the hose handle.
If you're not getting power here, this indicates that your hose has gone bad and needs to be replaced. We do carry all of the hoses for the Electrolux canisters, and most likely have the one for yours in stock. Please feel free to contact me if you need any further help.
Thank you,
Chris Jones
GoVacuum.com
May 13, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Need replacement parts and can't find them
go to geyser vacuum center.com he has hard to find parts .i'm sure he can help you
Apr 07, 2009 | Eureka 6983 Bagged Canister Vacuum
Cords for an Eureka Oxygen 6992A
Yes, that short cord in the power nozzle can be replaced and BOTH wands should also be replaced, not just the one that appears burnt. If your locan vac shop won't fix it, contact Eureka at the customer service number on the bottom of your vacuum. They will most likely set you up with the correct parts.
Oct 19, 2008 | Eureka Oxygen s 6992 Bagged Canister...
Lack of Suction
There are actually several possibilities.
Check to make sure that the brushroll is spinning. The brushroll is responsible for virtually all of your pickup on carpet, and is the culprit for most complaints of "lack of suction."
If the brushroll is not spinning, listen at the head to see if the motor inside the power head is active. If you can hear it running but the brushroll is not turning, you have a broken belt. If the motor in the power head is not turning at all you may have an electrical short in the hose, the wands, or the main power outlet from the body of the canister; but before you get too involved check the power head for a thermal reset button. Some of the Electrolux powerheads are equipped with these, and some are not, so check your user's manual. If there isn't one, or if it isn't tripped, you'll need to look for electrical issues.
In this particular model it is fairly common for the electrical contacts on the wands to short out, so inspect the metal contacts to look for scorching, or melting of the plastic around them. If you have access to a VOM, check for voltage at the contacts on the end of the wand, and if it is not present, check all of the contacts sequentially back to the canister body to determine which part is not passing voltage. If you have voltage all the way through the wand, you either have a loose connection inside the power head, or the power head motor has burned out. If you have power from the canister body, but not through the end of the hose, either your hose has a short in it, or the circuit board in the handle assembly that controls the power head power has shorted out.
If your brushroll is turning, then you do, in fact, have a clog somewhere inside the power head, which a visual inspection behind the brushroll and into the elbow will confirm.
Best of luck,
-R
Apr 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
98 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
