FOXCONN A690GM2MA-8EKRS2H BIOS UPDATE HELP NEEDED.
Hi,could someone explain to me how to update the bios on a foxconn a690gm2ma-8ekrs2h mobo,my computer does not have a floppy drive,is it possible to do this live online,any help would be very much appreciated.
  • 2 more comments
  • atticman01 Mar 15, 2008
    Hi iqbal, i followed your instructions,downloaded and extracted the files, now i have a 512kb rom file, a 34kb batch file, and a 112kb application file called afudos, but i cannot open any of the files, when i try to open the application file i get a black dos box on screen for 1 second and thats all, i would appreciate any further instructions,
    Many Thanks
    Damien.
  • atticman01 Mar 16, 2008
    Hi iqbal,
    we are getting very close {lol} i followed all your instrutions right until the last key and i got a message saying something like programme does not work with this operating system,i am sorry i should have said earlier that i was using vista ultimate,and i assume that this programme is for xp,is there a simular programme that will work with vista, or would it be easier to setup a temporary hdd with xp installed on it, and upgrade bios that way,sorry about this and i really appreciate your help.
    Damien
    Hi iqbal,i just setup a temp hdd with win xp installed and went through the whole process again but still im getting a error message saying This program cannot run under this operating system,on both vista & xp the process works fine right up until i see c:\newbios> then i type afu and press enter,thats when i get error message,wonder what problem might be.
    Damien.
  • atticman01 Mar 17, 2008
    Hi again iqbal, i finally got bios updated through foxconns live update,but it did not solve my problem, which was bios would not hold info,even with a new battery fitted,so i guess mobo is just faulty, Many thanks for your help,which im sure would have sorted my problem,if the board had not been faulty.
    Best Regards:
    Damien.
  • 655 Answers
Yaa its possible. Click on the following link:
http://www.x-drivers.com/catalog/bios_firmware/mainboards/companies/foxconn/models/a690gm2ma-8ekrs2h/7518.html
it will open the page from where you can download your driver.
What you have to do on this page is to type a code (display in a gray box) and then press on the link agains download. It will down load a zip archieve file. Extract the files and run the installation and enjoy.....:))
Thanks
Iqbal
Posted on Mar 15, 2008
  • Iqbal Husain
    Iqbal Husain Mar 16, 2008
    Thats great friend.
    1. The rom file is the data to be updated to your BIOS
    2. The batch file is installer, which uses exe file with parameters
    3. The exe file is updater application.
    Now what you have to do is to copy all the files in a same folder, lets say 'C:\newbios\'.
    Now if you want to see the message display by installer you should follow the following instruction.
    Step 1.) Start-> Run
    Step2.) Type CMD and press enter key.
    ..........It will open DOS prompt for you.
    ..........Like C:\WINDOWS (or it might be any other, don't worry about it.
    Step 3.) type this command cd\newbios and press enter, (assuming that you have copied all files in newbios folder of C driv.)
    Now your command prompt must be look like C:\NEWBIOS>
    if you got it then ok otherwise type EXIT and press return it will close your DOS command prompt, and try again from step 1.
    Step 4.) Type the bat file name i.e. AFU and press return.
    and now your bios is upgraded with a new version.
    Thanks
    Iqbal
  • Iqbal Husain
    The program is not OS specific, Its only to write some code to your ROM. Any way can you write the actuall error message, it will help me to analys whats going on.
    and you are welcome any time... hahaha its my pleasure to helping peoples
    Thanks
    Iqbal
Does dual core processor support Foxconn P9657AA-8EKRS2H mother board
The Foxconn P9657AA-8EKRS2H motherboard has a LGA 775 Socket. It will support Intel Core 2 Quad, Core 2 Extreme, and Core 2 Duo processors with an FSB of 1066 (800MHz). Thus is should support the dual core 775 processors. (Some Pentium 4, Pentium D and Celeron D CPUs may also be compatible with the board.)
I hope this helps.
May 06, 2012 | Foxconn P9657AA-8EKRS2H (6938279104065)...
Foxconn 945G7MA-8EKRS2 Motherboard will not post with pentium d cpu ,i have even updated with the lates bios flash,
Good day,
According to Intel 945G chipset supports Celeron D up to Core2Duo. Intel Gigabyte's 945 DS3 even supports up to Core2Quad. GByte Foxconn has 3 mobo bios from there site. Foxconn
According to their date: Latest to oldest
4BFF1P56 No Version 4BFF1P40
Have you tried installing the no version bios? In my experience some latest bios have some problems with other devices so try to use the no version bios. or try a different mobo bios with the same chipset from Foxconn. below are two foxconn mobo models i can't see the difference.
945G7MA-8EKRS2 945G7MA-8EKRS2H
Update at your own risk..
hope this helps, thanks for posting.
Jul 01, 2011 | Foxconn 945G7MA-8EKRS2 945G P4/Pentium...
Repeated failure to load Windows 7 HP
Hi.
Foxconn don't have this board on their list of their Windows 7 supported chipsets (which is hardly surprising), but as you state all your individual components should be perfectly OK with Windows 7 .
I suggest you flash the Bios because Foxconn had to produce a new Bios for Vista in order for that OS to run correctly.
Best of luck.
Jan 31, 2010 | Foxconn P9657AA-8EKRS2H (6938279104065)...
Will not power down, bios code 7F,
You need to check the mobo front panel PWR and RESETconnections as they must be wrong if youve connected them yourself
Aug 27, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
Can,t overclock after update bios(foxconn p4m800p7ma)
Try clearing the CMOS (CMOS reset)...and restoring defualt bios
May 08, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Requared bios updated versin for foxconn 865gv chipset mother board
Hi, I run a foxconn mobo myself and yes its a great board. But dont go to the foxconn site looking for downloads. instead go to the VIA site they make the chips and you will get more sense there. If all else fails Foxconn do have a "Contact us " link on their home page. This will give you the company email address and you could request directions to the update site there, the only trouble is it could take weeks to get a response. Regards mistyman
Aug 20, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
444 people viewed this question
David Payne
David Payne
