Question about Kenmore 64902 Electric Dryer
Dryer Thermal Fuse
I have a Whirlpool Electric Dryer and I replaced the Thermal Fuse and it didn't make it through 1 drying cycle before it blew again. Can you help me trouble shoot why the Thermal Fuse is repeatedly blowing. Thanks.
    Problem Solver:
  • 8 Answers
Air flow could be the issue or if your heater itself is grounded against the cabinet i think your unit is getting to hot check all your vent lines if you have good air flow check the heater try taking the vent totally off for a few cycles and see if the fuse blows agian
Posted on Mar 24, 2008
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Dryer not working
    check to see if your vents are clogged its the num. 1 reason. if they are most likely your thermal fuse blew out, have it replaced. Another reason is your heating element went bad. Check for continuity on both items.
    Apr 16, 2010 | Whirlpool LER4634J Electric Dryer
    Whirlpool Dryer Does not dry
    Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
    The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
    Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
    Dryer won't shut off at end of cycle
    First of all if you want heat it's probably a burnt up thermal fuse due to lack of air to the dryer. But if the timer is getting stuck you'll just have to replace the timer. Theres no way of fixing the timer just replace it and then replace the thermal fuse (it's located on the back of the dryer) and you should be up and running also have the ducting cleaned out.
    Please remember to unplug the dryer before working on it.
    Hope this helps
    Jason
    Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
    either you are pushing the dryer back to far and crushing the exhaust vent hose .your exhaust vent going outside is stopped up , or your low temp thermo will not let the dryer cycle and it is over heating.
    Feb 27, 2008 | Dryers
    sounds like something getting to hot, perhaps clclyng thermo not regulating temp properly, although cleaned vent, when you pushed it back ito place did you crush or hkink line? peek over top and check
    Feb 27, 2008 | Whirlpool GEW9250 Electric Dryer
    Whirlpool Duet Dryer
    My dryer did the same thing, all the lights worked on front, but the bulb was out inside. All I had to do was to replace the thermal fuse and replace the bulb if you want light. The bulb don't have to work in order to dry clothes
    Jan 03, 2008 | Whirlpool GEW9250 Electric Dryer
    Kenmore 64902 Electric Dryer Logo
    162 people viewed this question
    Top Kenmore Dryers Experts
    Sal De
    Marvin
    Marvin
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
