Question about Watches
Setting my digital watch
I was just given an older kessel dual time digital watch. I put a new batery in it this morning and it is running fine but I cannot figure out how to set it. Can you help???
  • 796 Answers
HOW MANY BUTTONS DO YOU SEE IN THE SIDES....
PRESSING IT EACH TIME MOVES THE MINUTE HAND BY ONE MINUTE...
CONTINUE TO DO IT TILL YOU REACH THE CURRENT TIME
Posted on Mar 15, 2008
  • 1 more comment
  • isaac johny
    isaac johny Mar 15, 2008
    SETTING NORMAL TIME
    • In normal time mode, Hold L2 for 2 seconds to alarm time set
    mode, then L2 again to normal time set mode, the second digits
    begin flashing.
    • Press R2 to reset the seconds to “00”, press R1 to switch to the
    minute digits.
    • Press R2 to advance the minutes. Press R1 to switch to the hour
    digits.
    • Press R2 to advance the hour. Press R1 to switch to the date.
    • Once the date is set, press L2 to return to Normal Time Mode.
  • isaac johny
    12/24 HOURS MODE
    • In normal time mode, press R2 to display alarm time.
    • Hold R2 and press L2 to select 12 or 24 hour format.
    • The “PM” or “AM” symbol on the displat means both
    normal time and alarm time are in 12 hour format.
    Otherwise, they are in 24 hour format.
  • isaac johny
    THANK`S ANGEL,...
    REGARDS
    JOHNYCHEL
SOURCE:
I can't get the analog time on kennth Cole kc9110 watch after changing battery the digital part in running fine please help thank you
With this type of dual display watch, the two 'mechanisms' are often independant with their own batteries. It's quite possible that the battery for the analogue display has been missed - often they are underneath the battery for the digital display with an insulating cover to isolate the batteries from each other. Sometimes it's even necessary to remove the digital module to get to the analogue module. Obviously, you would need some experience of dismantling watches (and to be very careful) to sort this out. If you don't feel confident, and you value the watch, take it to a professional.
Jul 11, 2015 | Watches
Brand New Watch second hand won't move. won't keep time.
The watch has a problem in the timing module and the second hand won't move (a cog wheel issue) this is clearly a manufacture defect that can not be remedied and should be returned since it is under warranty.
Feb 27, 2011 | Fossil Watch Style # ES2074
Setting analogue time on a Crane & Viceroy Radio controlled watch
I haven't been able to locate your watch but since watches tend to be similar in operation, I suggest that you look at the instructions for my watch and try a similar settings.
Go to "http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf" and instructions for a Casio watch will appear. Go to page 4 and read instructions under "to adjust analogue time".
Mar 30, 2010 | Watches
G Shock G-600 Reset
Dual batteries should be installed [+ to -][+ to -]. There may be a hard-to-read diagram that shows installation. You may have to take the watch to a jeweler to get things straightened out.
Apr 26, 2017 | Casio G-Shock G600-1AV Wrist Watch
How do i take my george watch out of 24 hour time?
how do you set the time on the digital george watches?
Nov 21, 2009 | Watches
How do I set time on digital Joe Boxer A126-03?
Press the mode button 3 times. Use the lap/rst button to switch to the min/hr/date field you want to change. Use the st./stp button to change values. When finished, hit the mode button again.
Mar 11, 2009 | Tommy Bahama Islander Dual Time Date Watch...
good morning ! to set the sharp watches is need to use the setting button ! first , press the adjust button up to 3 second after th digit blinking press the mode button to select the digit that you want to chagne and press the reset button to chagne tha digit to the corect time after setting press once the adjust button to time back to normal ! good luck ! ....
Sep 10, 2008 | Watches
10 year old alarm chronograph
good morning ! your anadigi chronograph 388 is veery easy to operate,just change the battery then short the reset button the fix the case back and set the time use the crown and the button to set the time calendar and the alarm !thank you ! god bless !....
Sep 01, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Dual Time
You can download the manual from the link below: http://world.casio.com/wat/download/en/manual/? You need to input the four digit code from the back of the watch. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | Casio AWS90D-2AV Wrist Watch
Watches Logo
364 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
