Whirlpool washer has stoped and service light is on
  • tommytbayr47 Mar 15, 2008
    i now ther is a problem and the service light is on how do i check it out and sort it i do repair cars all day so have the tools i need help to under stand the problem
    Novelist:
  • 142 Answers
Something has happened within the unit that the computer has determined requires immediate attention. Best bet is to have it serviced. There's usually not much you can do without a method of determining the error code. The unit might have to be reset by the repair shop, and they'll determine the problem there.
Posted on Mar 15, 2008
SOURCE:
My wfw9050xw stoped in the middle of a wash. It wont spin, drain,wash or do anything. when I unplug it and plug it back in, I can press the control button ang og to drain , but it spins about 3/4 turn and...
Anonymous:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Mar 07, 2018 | Whirlpool Duet WFW9050XW Washer
Wash macahine keeps stoping in the middle of a cyle with an F1 code & I don't have the manual
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Lights flashing, F24 flashing washer has stoped
Hi
Thanks for using FixYa. F24 is a water temperature sensor error which is caused when the water temp. sensor value is out of range during the water heating step of the wash cycle. To resolve this issue you’ll have to check the water temperature sensor and its connections. If everything seems to be working fine then you’ll have to replace the water temp.sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stopes after filling with water and does nothing
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Aug 07, 2010 | Kenmore 22422 Top Load Washer
Code f 21 slow drain or stopped up . the drain lines are clear wh
Did you check to see if it is stoped up between the tub and the pump socks or somthing stops it up somtimes also check that the pump is turning and is not stoped up.
Jul 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code 40
According to the Whirlpool installation and maintenance manual:
F _ _ “F##” code
Press PAUSE/CANCEL once to clear code.
Press START. If code appears again, call for
service.
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool washer stoped after the agitate cycle
If it fills with water, agitates then stops still full of water (even if you manually advance the timer), you have a bad lid switch. This is an inexpensive repair, or even a do it yourself project.
May 19, 2009 | Whirlpool Washing Machines
Grinding noise when washer starts some spin cycles, washer stoped and game my wife a f-33 reading. whirlpool told me to unplug(reset) the washer for 30 mins. i did this and the washer still has the...
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
Oct 11, 2008 | Whirlpool Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
