Question about Palm TX Handheld
Lifedrive i replaced the battery in my lifedrive and now the screen will not come on I hear sound and the power light is on but no screen. Any suggestions?
    Problem Solver:
  • 36 Answers
Sounds like the connector for the screen did not get reconnected properly. It's a tricky operation. Take it apart and try again.
Posted on Mar 19, 2008
SOURCE:
Lifedrive won't start. Neither will it reset,
Unfortunetly that usually indicates the harddrive has failed on you. Try a power on hard reset. It is the same as the hard reset but the power need to be plugged in as well.
If you look there are several places that will replace the drive with either a new drive of a compact flash card. The card is the way to go as it increases battery life but is about 10x faster acessing stuff.
Dec 13, 2009 | Palm LifeDrive Mobile Manager Handheld
My palm doesn't seem to be charging at all. The
The clicking noise usually indicates a hard drive problem. There are replacements available. You can get a replacement hard drive or a flash card drive. Of the two the flash drive is by far the better choice.
Nov 06, 2009 | Palm LifeDrive Mobile Manager Handheld
When the lifedrive dies duo harddisk, there are
You have two options one is of course a replacement drive but the other is replacing the little hard drive with a flash disk. The flash drive is nothing more than a 4gb compact flash memory card that happens to use the same connector as the Hitachi hard drive. Of the two I'd go flash myself.
The flash disk is faster and uses far less power so your battery life can increase by quite a bit. I think it is something like 10% of the power. Next to the display this is the single biggest power item. I've heard of the useful battery life increasing anywhere from 3x to about 6x after doing this. You can get the drive or flash from several places online. These are the same CF cards as used in many cameras. Most also offer the installation service.
Here is a link to one place but do a few searches and compare prices etc. Just search for lifedrive, flash, drive or lifedrive hard drive replacement and you should get quite a few.
http://www.usedpdaparts.com/Lifedrive.html
Jul 12, 2009 | Palm LifeDrive Handheld
Palm LifeDrive not charging
I had the exact same annoying problem. Easy fix though. Get the palm universal cradle. The power connector is either worn or loose and making partial contact. So when you use the normal adapter there might be a position that works but generally it won't. When you use the cradle the weight of the LD presses the contacts more and it will behave.
I went through a couple of chargers before getting the cradle and fixing it once and for all.
Apr 16, 2008 | Palm LifeDrive Mobile Manager Handheld
Palm lifedrive frozen 'secure erase'
You may be experiecing failure of the microdrive. Those are typical of it failing or having failed.
Having said that have your tried the hard reset buy holding the 5 way down while sliding the power switch? This is slightly different than the older secure but you need the update 2 to have it. This will erase and reformat and reload the entire system a bit more thouroughly than the older secure erase.
It might get you out of the cycle which is more important.
Feb 16, 2008 | Palm LifeDrive Handheld
Lifedrive won't power on
When you plug the unit into the wall to charge, poke the reset hole in the back of it at the same time. This should reset the internal recharging mechanism in the Palm. Let it sit for a couple of hours and then see if it will come on.
Jan 03, 2008 | Palm LifeDrive Handheld
Palm Lifedrive failure
I found this on the Palm website about the frozen Palm Logo screen
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=97,E=0000000000825271086,K=7324,Sxi=2,Case=Obj(26419)
Dec 03, 2007 | Palm LifeDrive Handheld
Battery not holding a charge, maybe...
The only thing close that I can recommend is doing an in cradle reset. Palms site says it only works on certain models, but hey it's worth a shot.
Nov 26, 2007 | Palm LifeDrive Handheld
My Lifedrive won't boot up
Seems the LifeDrive Micro Drive is the killer on these Palms. Mine did the same thing and after extensive online research I found that the micro drive can be replaced with a Compact Flash card which is much more reliable. Apparently there are only certain CF cards that work with the LifeDrive though. I have found at least one retailer that sells a compatible CF preloaded with the Lifedrive software. The route I took for repair was to send it out to a guy that advertises his service on eBay. You send in the LifeDrive, he diagnoses it for $5, and can install the CF card with software for $89 (he waives the $5 if you have him fix it). I am looking forward to getting mine back in permanent working order! Here is the link:
http://myworld.ebay.com/itsnothere/
Oct 14, 2007 | Palm LifeDrive Mobile Manager Handheld
Dead Harddrive
YOU NEED TO BUY A NEW ONE SOUNDS LIKE THE ACTUAL THING HAS BLOWN
Apr 13, 2007 | Palm LifeDrive Mobile Manager Handheld
Palm TX Handheld Logo
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
