Question about Air Purifiers
30965 HEPAtech Air purifier - daughter dropped popsicle sticks inside - help!
My daughter dropped popsicle sticks in side the top of our Hunter air purifier. How do I open the top compartment to retrieve them? The top compartment seems to loosen as I pull on it - is there a trick for removing it? Also - The air flow will occasionally stop and then resume - is this normal? We keep it on cycle 2. I think it's due to being on cycle 2, my hubby says it's broken due to the popsicle sticks. Thank you!
Yes
Posted on Apr 01, 2008
Hunter 30201 air purifier on light is on, fan not working...
may need to replace the fan on your air purifier most of them look like some sorta computer PC fan shouldnt be too hard to replace hopefully
Feb 22, 2017 | Hunter Air Purifiers
Hunter hepatech 40882 uvc air purifier won't turn after cleaned filters
Hello, this is Ava with Think Crucial.
Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=hunter
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 24, 2016 | Hunter Air Purifiers
Hunter Air Purifier making screaming noise
Most likely the problem is a bad bearing in the fan motor.
May 31, 2012 | Hunter Fan Company 30251 Air Purifier
Owner manual for hunter 30747 Air Purifier
You may refer to this online manual for your model number to help you put back the filters in your unit.
Hunter 30747 Instruction Manual
https://www.thinkcrucial.com/search?type=product&q=hunter
Ava B.
May 19, 2012 | Hunter Air Purifiers
Can I get an owners manual for Hunter 30525 air purifier?
Yes, manuals are available from Hunter Air Technical Support. Call: 888-830-1326
Be sure to have the correct Model Number handy, when calling. As some models have been discontinued, but are still supported by Hunter Air.
Hope this helped you.
Apr 21, 2011 | Hunter HEPAtech Air Purifier and Ionizer -...
Cannot find manuel, need to reset after replacing filters.
How to reset Hunter quietflo air filter, won't start up.
Jul 10, 2009 | Hunter QuietFlo 225 Air Purifier
I need a wiring guide for the Hunter Hepatech 30057. The switch wires have come apart. Thanks.
i normally dont help people in this matter , but I can understand your problem . go to www.ytb.com/gizelle & click on "view company presentation ". This should help !
May 01, 2009 | Air Purifiers
Lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Mar 22, 2009 | Hunter (30067) Air Purifier
Model 717 no longer working...can this be b/c i never changed filter?
Honestly, whether there's a filter problem or not, the screen should boot up period. If you still have your manual that came with your machine, look up troubleshooting steps provided by the company. (might want to take a look at the warranty for a possible repair under manufacturers warranty). A very familiar hard reset is to unplug the machine, and hold down the power button for a minute (yes, unplugged) then release, plug it in, and try to turn it on. if that doesnt work, I'd attempt to unplug, press all the buttons on the machine once individually, then try again plugging it in, and turning it on. Try all this in a seperate outlet... If it fails, definately call their customer support, cus it may be a defect in the chipset.
Dec 28, 2007 | Hunter HEPAtech 715 (2 Pack) Air Purifier
Air purifier HUNTER 30200
I hope this is not to late. This is an old post. But I have this same air cleaner. It does prove difficult at first to open and it feels like you are going to break it.
On the sides about two to three inches down is a large indentation. Slide your fingers in there and gently but firmly pull the face plate of the air cleaner off. The air cleaner is as big as the front of the air cleaner. It will slide right out. I hope this helps.
Nov 20, 2007 | Hunter 30200 \ 30010 (Set) Air Purifier
Air Purifiers Logo
118 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
