Question about Whirlpool Duet GHW9150P Front Load Washer
A display of hf, and the water intake piece
The display on the washing machine says hf, which means insufficient water intake. I have cleaned the piece that intakes water, but it is still clogged. It is only the cold water intake that is clogged. Do I have to buy a new piece for the washer or is there a way of unclogging it?
    President:
  • Whirlpool Master
  • 2,651 Answers
No way to unclog other than removing sedimet from screen assy. internally nothing need to replace.inlet watervalve 1 piece for both hot and cold water.
Posted on Mar 15, 2008
No water is getting into the washing machine. Error code display and soap is still in dispenser.
machines have a hot water and a cold water intake
if the water cold isnt getting to the blue intake it wont work
as you have an error code
post the error code it displays
you posted insufficient info to come to a good recon
Sep 24, 2014 | LG WM0642HW 4.0 cu. ft. Front Load Washer
My front loader is reading FH or possibly HF what does this mean?
Water not getting into machine . Check your hoses and screens to make sure they are clean. If you hear a hum but no water enters machine then they are plugged or shut off . If no hum then the fill valve may be bad.
Nov 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT DOES HF MEAN
Hello
FH or HF error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Nov 17, 2010 | Kenmore Elite 45986 Front Load Washer
What does the error code HF mean?
It means you have an insufficient water supply problem. My Maytag is doing the same thing. I'm currently only using cold water to wash clothes and I have the valve for my hot water supply closed because it's leaking. So...if my washer is set to use anything but cold water it will stop mid-cycle and display the same thing because when it tries to "pull" hot/warm water it's not getting any. Make sure your valves are opened up completely, and if they are make sure water is actually coming out of both of them. You may have to disconnect them from the washer to check. Hope this helps!!
Oct 01, 2010 | Kenmore Elite 45986 Front Load Washer
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
Possible causes for HF error. It is in the cold
Hi
Thanks for using FixYa. You are right, FH error indicates an issue with the water supply; this error occurs when after 30 seconds the control does not detect the water entering the machine and the valves turn off & error code is displayed. Check the cold water inlet valve for any clogs and try to clean it, also clean the screens in the inlet valve. If still it’s not resolved then the only option is to replace the valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error H F
My Manual says (HF) = Water Inlet Problem- Insufficient Water Supply
Select Pause/Cancel twice to cancel cycle - Unplug Washer to disconnect Power-
Water faucets completely turned on
Screens at inlet hose connection to washer clogged?
Water inlet hoses kinked?
Plug in the washer- re-select cycle and press hold to start-
same error- call for service..
May 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean when the machine stops mid cycle and H and then F displays in the digital window?
I think that means NO, Hot water Flow (HF)
Try this Hold the "Start" button IN while you Switch ON.
Also check this out pull the water lines filters to check the screens, and the cold water line for crud in it
Feb 16, 2010 | Frigidaire ATF6000ES Front Load Washer
WASHER DID HAVE hf ON IT, NOW THERE IS NOTHING ON THE DISPLAY AT ALL AND DOOR IS LOCKED. VERIFIED BREAKER IS NOT TRIPPED AND POWER IS GOOD. NOTHING IS IN THE STRAINER EITHER, BUT DID DRAIN ALL THE WATER IT...
hf is: hot water fault meaning that the hot water could not enter the machine through the water valve or, the computer did not "see" the water entering. as it expected ( are both of your faucets fully on?) manually unlock the door using the emergency door release then check the water valve assembly (where you attach the hot and, cold hoses) for problems.
next; push and, hold the on button while someone plugs in the machine to reset the computer and, restore your display
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
538 people viewed this question
Dan Webster
Dan Webster
Sal De
