Lexmark 2500 and turning off alignment
I like this printer but it wants to print an alignment page whenever it is low on ink and when I install new cartridges. This is very annoying (and uses a lot of ink)! Can I turn this feature off?
thanks
  • Anonymous Aug 02, 2008
    Very annoying, it does it even when i don't change cartridges. i want to turn this **** off
  • Anonymous May 03, 2009
    I personally have been using an uncalibrated printer for over a year now (because I always dismiss the annoying message), and I have never had any issues.
    It IS stupid.
    It DOES need to go...(check my proof above; 1 1/2 years sans "calibration").
    I'm sure there is some sort of registry switch that would do it...
IT"S STUPID!
Posted on Aug 22, 2008
    Genius:
  • 3,587 Answers
Nope..it's part of the reset for any printer..and a good idea, to ensure that you are working with a printer that is calibrated..
Posted on Mar 15, 2008
SOURCE:
Why do I have to waste all my ink on an alignment page everytime I put in a new cartridge? Why can I wait to see if my printer needs to be aligned? Is there some way to turn this bothersome step off and...
The printer is designed to align the cartridges whenever it is re-inserted in the cartridge carrier. You can press the Cancel button to disregard the alignment funtion. However, Lexmark does not recommend this action. This is to ensure proper printing on the paper.
Aug 08, 2011 | Lexmark X5470 All-In-One InkJet Printer
Do I NEED 2 ink cartridges on the Lexmark 2500. Never use the color ink. Installed new black cartridge, did the alignment and now printer won't let me print. Help
Yes you do need 2.
All ink cartridge bays has to be filled with a working cartridge, for the print driver to allow you to print. That is why I prefer single ink type printers, so it is not so expensive to maintain the inks you don't use.
Mar 10, 2010 | Lexmark X2500 All-In-One Printer
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
Color ink want print after installing new cartridge
have you installed the cartridge correctly??? make sure you did
try to print a few pages, to get the ink going.
try test pages, try the aligning procedures as well.
Mar 26, 2009 | Lexmark Z515M InkJet Printer
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
My printer is new and jus instal a new ink
you need to align the cartridges whenever you install the new cartridges and/or you install the printer.
Go to Start >> Printers and Faxes >> Select your printer
Right Click on the printer and click on Services Tab and
Press
"Align the Print cartridges"
Make sure the Printer is turned on
it will Print one Alignment Page
Choose the best aligned option and Select on your Computer Screen
I hope this will solve ur problem
Best Of Luck
Dec 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing Blank Pages
Try checking the ink cartridges and make sure they have ink in them or it will keep printing blank pages. Then try printing a test page by going to control panel, clicking on printers and faxes and right clicking on your printer and going to properties. Then go all the way down to the bottom of the page and click print test page. It will clean the printer cartridges and align them to print correctly. It should work after that.
Nov 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
No printing
If you brought new Lexmark cartridges please change it as it comes with one year warranty but before try to perform a self test, (i.e make a copy) if it works then try printing , if get the error then change the cart.........................
May 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
How do you align your printer
WTF...wheres the solution. Bunch a ****!
Oct 14, 2007 | Lexmark X2470 All-In-One InkJet Printer
Open Questions:
706 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
