Question about Toshiba Satellite 5005-S504 Notebook
Toshiba 5005-S504 satelite
Power supply plugged in and battery light is flashing, But machine will not power up
  • babasystem Dec 29, 2008
    sound not working
  • 30 Answers
Try taking the battery out and booting with just the power cord inserted. If you are still getting no power then the laptop is most likely dead. Good luck.
Posted on Mar 15, 2008
    Sergeant:
    Champion:
  • 256 Answers
Check power adapter and your power cord. Your battery is not charging....
Where is the cmos battery for Toshiba 5005-s504
You will have to open up the '**** shell' and remove all of the B25 and F6 screws from the bottom, as well as the B16 and B6 screws under the keyboard. To remove the keyboard, I had to pry up the trim piece that holds the power button and remove three screws. Be careful of the wireless wire leads, as you'll be tempted rip them out!
The CMOS battery will be under the right side of the hand rest, next to the mouse. It has two leads and the battery is in a blue 'bag'.
Nov 20, 2009 | Toshiba Satellite 5005-S504 Notebook
Where is the cmos battery located on a toshiba satelite A105-s2131
There are several access panels on bottom of your laptop. These should have markings that designate what is behind each. CMOS battery can be either behind the hard drive panel or the memory card panel.
Alternatley, you can try this link to Tom's Hardware where someone is discussing how to do on a similar model. http://www.tomshardware.com/forum/247842-30-replace-cmos-battery-toshiba-satellite
Oct 11, 2009 | Toshiba Satellite 5005-S504 Notebook
5005-S504 recovery disk says Wrong Machine. downloaded new bios years ago to prevent overheating per Toshiba. Can I still use recovery? Does Toshiba still offer bios upgrade
Yes but this is nothing to do with recovery disk if it is original Toshiba. Check your HDD as external to see if any partition is inside. If you wanted to install new program, then format the harddisk with external connection. If you had vista upgraded, it may say wrong machine but I doubt it.
JMC
Aug 15, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Getting memory error on front display immediately on power up
It is surely indicating issue with the memory.
Can try to reseat the memory (remove from slot and reinsert again) make sure to wipe the contact with soft tissue.
If still facing issue then replace the memory.
Apr 30, 2009 | Toshiba Satellite 5005-S504 Notebook
Toshiba satellite 5005-S504 Secure Digital Card Slot problem
Hi there
Take a close look inside the card slot (you may need a torch/flashlight) look to see if any of the brass pins are bent or out of position, if they are use a very small flat head screwdriver to gently push them back into place.
If all looks fine with the slot and there are no foreign objects inside your card maybe faulty.
Also i suggest the you check the drivers are installed, check this in device manager.
Good luck and thanks for using FixYa!!
Apr 03, 2009 | Toshiba Satellite 5005-S504 Notebook
Changing BIOS priority on toshiba satelite 5005-s504
as i recall, ntloader is software for the OS load, after hardware boot, so you already passed up your chance to enter bios, which you realize. i used to have a toshiba laptop, was it the delete key or F2 to enter BIOS? try delete, and make sure youre pressing it from restart like once a second as it's booting to make sure you hit it in the windows of time it's looking for key presses before it's time to load the operating system. you'll be fine. it's just unnerving to be locked out like that...
Feb 01, 2009 | Toshiba Satellite 5005-S504 Notebook
Can't recover
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Oct 24, 2008 | Toshiba Satellite 5005-S504 Notebook
Looking for Toshiba 5005 cd/dvd drivers
this link will take you to the support page
select portables, satelitte, click on archived models, then select 5005-S504-507-or 508 whichever it is.
once selected click on show results
click on drivers.
Apr 05, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
180 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
