Question about Bosch Axxis WTL 6003 Electric Dryer
Bosch Dryer squeaking noise
When the dryer is in reverse drying mode, there is a squeaking sound as if some form of lubrication is required. I cannot seem to be able to get at the spot where the squeek is coming from but it s/b the motor. Is there an owners manual online to help me take apart the dryer?
  • sarah571 Dec 16, 2008
    Did you find a solution? I have the same problem.
    Problem Solver:
  • 5 Answers
I have not seen any service manuals online. The squeak will possibly be a rubber bush used to silence the machine. If you get it stripped down you should be able to locate the squeak by carefully applying pressure in different areas and the squeak should go... then hopefully you will have found the culprit.
Posted on Feb 20, 2010
We also have a bad squeak in our Bosch dryer that drives you crazy. The Bosch serviceman when he came to look at the problem said his own machine did the same and he gave up trying to fix it, cheaper to put up with the noise. I purchased Bosch because I thought it was one of the best, I will not be buying Bosch again!
Posted on Apr 18, 2010
How to repair squeaking sound when in operation
it most commonly has to do with the inner wheels needing to be replaced. either the tub wheels or belt wheel.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
May 19, 2014 | Maytag Bravos MEDB200VQ 29" Electric Dryer...
Squeaking sound in dryer at the beginning of each drying cycle that for the most part goes away after 5-10 minutes.
you could have a rusted idler or drum roller. need to take dryer apart and look at them. use mineral oil or special bearing oil to lubricate it.
Feb 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Asko TD 70 intermitent squeaking replaced belt and brushes about 2 yrs ago maybe a loose roler or replacement or lubrication?
For intermittent squeaking-
You have to remove the back of the dryer and expose the motor and drive assemblies.
Check the drive belt idler pulley
Check for any strange sounds coming from the motor
Check the drum support rollers - they support the dryer drum, usually in 3 places. They can sometimes be lubricated, but generally don't last that long because there is usually roller shaft damage by then, requiring replacement.
Jan 06, 2010 | Dryers
While drying for short time the dryer starts to squeak
Probably a dry bearing
.You would have to gain access into the dryer to establish which bearing/s it is.
You would then need to see if lubricating the bearing/s, would cure the squeak..
If it does not, then you may have to fit a new bearing/s.\
Hope this helps.
Dec 22, 2009 | Maytag Dryers
My dryer is squeaking intermittently while drying.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 15, 2009 | Maytag PYE2300AY Electric Dryer
Squeak when running the dryer
It's the roller axles and/or the motor shaft. Remove the front of the dryer and lubricate same.
May 27, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Squeaks and sqeals during dry cycle
Lubricate the contact points, pulleys , change the felt seal .
Get a new dryer, abot time?
Vitally
May 14, 2009 | Dryers
Constant squeeking while drying clothes
It's most likely the roller bushigs/axles which need lubricating -- they've probably not failed yet, but will if ignored.
They squeak more when clothes are wet because of more weight.
I'd also lubricate the motor while your in there.
May 08, 2009 | Dryers
When dryer is on it continually makes squeaking sound
You need some lubrication inside the dryer. There are several pulleys and a belt tensioner that can be noisy if not properly lubricated. Be careful to use only an approved lubricant to avoid a possible fire hazard.
Dec 30, 2008 | Dryers
Bosch Axxis WTL 6003 Electric Dryer Logo
1,101 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
