Back to:
Tags:
Jamo 1060 SW Speaker
I have no amp for jamo 1060 sub
posted by big_red533 on Mar 15, 2008
How do I power the subwoofer Jamo 1060? I have a Denon avr 2807 amp. Do I need a monoblock amp? The sub has two line inputs.
Thanks.
Comment by big_red533, posted on Mar 20, 2008
Thanks sanjin. Will this work as a sub or just a duel speaker in a stereo enviroment. I was going to use it for a home theater sub.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 18, 2008
Helpful (85)
sanjin
Rank:Guru Guru
Rating: 88%, 31 votes
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Comment by sanjin, posted on Mar 23, 2008
It looks that it has passive crossover inside so it should work as a sub
Rating Locked! (?) big_red533 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I have no amp for jamo 1060 sub:
I don't want to Accept this solution
Solution #2
posted on May 26, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
in a home theater setup, a good idea would be to use a mininum 5.1 channel amp, here there will be a seperate output on the amp ( called sub out or LFE : low frequency effects) which is a dedicated channel for the subwoofer. in stereo setups the above mentioned is absolutely correct the sub out will go any of the inputs on the subwoofer
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Home Theater Speakers and Subwoofers problems?
I have a krk submonitor that I use with my av reciever and...
I ordered the caps that you specified in your fix. Do you...
hi i have a telefunken surround sound that i cannot get to...
I can't play mp3 and dvds that i copied from my pc. Seems...
Hello, Problem with Panasonic home theatre model SA-HT540...
Loading problems.
Repair Service
Find Home Theater Spe. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
