Question about Frigidaire FGQ332ES Gas Dryer
Gallery gas dryer
Thought the belt burnt, looked inside, its the motor, it runs a couple seconds, stops and has a burning smell.Cant find how to disconnect the motor from the front exhaust unit
    President:
  • Frigidaire Master
  • 2,651 Answers
One of 2 ways, diagram wasnt very helpful. the blower wheel either is threaded on the motor of is held on with a clamp. the clamp obviously undo and the motor will slide out, if its threaded look closely around fave of wheel you will see the words remove, with arrows if the direction to turn. Some are reversed thread. in which case you need to hold opposite side motor shaft with correct size wrench and unscrew from front( you wont have to completely remove the blower from housing it'll come forward enough to remove.the motor itself is held in by 2 plastic hold downs one in front and behind the motor.
Posted on Mar 15, 2008
My Frigidaire gallery dryer stopped working it will buzz when I turn the starter knob but never starts nor does the drum turn ,then I smell a burning smell
if you can hear the motor running then probably the belt is either too loose and/or broken (you may hear a rubbing or squeeling sound).....if you cant hear the motor running then it may be burned out....a very acidy smell.
Either problem requires taking the dryer apart to fix (new belt or new motor)
May 03, 2016 | Frigidaire Dryers
My kenmore dryer turns on, but i hear a loud clinking noise (like metal rolling around) and it starts to smell like burning. One of the vents inside the tumler is actually black and burnt looking now. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 18, 2011 | Kenmore 500 6952 Dryer
My dryer stopped running in mid cycle and there was a burning smell. I thought it may be the belt, but it is not the belt. Also, the light inside the dryer hasn't worked for years, so I don't think...
heatman101
Jun 15, 2011 | Maytag HYE3658AY Electric Dryer
I have figidaire gallery dryer model fsec748gf d'ont start.i heard timer motor did tic,tic but the electrical motor not turn and did not smell burn. thank you for your support. Michel
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 05, 2011 | Dryers
I sensed a bad burning smell from dryer motor. The dryer drum belt is still looking good and tight. The 4 drum rollers supporting the drum are looking good and no friction. The dryer shut itself...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 17, 2010 | Whirlpool LGB6300 Gas Dryer
Our kenmore dryer is 6 years old , model# 110.63102101 at first the drum wouldn't turn,and we would get it to turn by using our hand , last week it smelled liked it was burning, so let it rest and then it...
In your case the motor probably has gone bad....you are looking at a 200-400.00 repair, so go from there...
heatman101
Nov 04, 2010 | Kenmore 62602 Electric Dryer
Kenmore gas dryer made a loud buzzing sound and didn't start. I smelled burnt rubber smell. Dryer is totally unresponsive now. Breaker is ok, power is on.
Sounds like the belt has burned and broken. There is a switch on the tensioner that will not let the motor run if the belt breaks.
Dec 28, 2009 | Kenmore Dryers
The panel lights up and but does not run after start button
heatman101
Sep 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Frigidaire Gallery dryer SMELLED like Burning rubber.
Reach inside and try to turn the drum. If it seems hard to turn then your glide kit (Part#5303937139) may be in need of replacement:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | Dryers
Gas Dryer
Check tube belt or motor geting hot.
Nov 11, 2007 | Dryers
Frigidaire FGQ332ES Gas Dryer Logo
71 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
