Question about Panasonic PT-65WX51 65" Rear Projection Television
Can't get full screen
Hi, Can anybody help? We recently bought our TV used and can't figure out how to get a full picture. The picture is centered on the screen but doesn't cover the full screen, it leaves about 8" on each dark.
Thanks, Deedee
  • ssol Mar 16, 2008
    Sorry, Basically the picture isn't fit to the full size of the screen, 8" on each end of the screen is not being used, but remains dark. I'm starting to think that maybe I don't have the right remote for this unit, because I don't have a format button on the one that I've got.
    Scholar:
  • 146 Answers
What does "8 inches on each dark" mean? you can try the format button on the remote and see of this will fix it.
Posted on Mar 15, 2008
Cannot change the picture back to full screen. remote control want return the picture to full screen with the
Hi, Turn your TV on, select the menu and see if there is something in picture settings (wide screen or full screen) Try to connect a DVD player using HDMI cable. See if there is any difference.
Some DVD players will also have screen sizing. If nothing helps contact TV repair. Good luck
Jul 24, 2011 | Hitachi CLU-5713TSI Remote Control
How to make a flt screen in to full screen picture
On your remote there should be a ZOOM button that will strech the screen to full screen it may not be a desirable look but most formats today for HD tv is widescreen format also in your menu system you can change this as well. thanks for using fixya please click the accept button.
Aug 18, 2009 | Insignia IS-LCDTV32 32 in. Television
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Elmo slide to video projector
check the resolution. is your tv hd? the projector may not be.
Aug 20, 2008 | Elmo Projectors TRS-35XG 35mm 80 Slides...
Screen is off centered
Every tv has a secret service menu accessed through a secret sequence of buttons on your non-secret remote.
With the power off, press this button sequence:
mute
power on
You should now be seeing the secret service menu.
TOUCH NOTHING IF YOU DON'T KNOW WHAT IT DOES!!!!!!!!!
Before you touch ANYTHING write down what the initial setting was. I mean it mister.
I think hitting volume down selects an option, while hitting "menu" takes you out of that option and into the area you were just in. There are lots of things to do here.
Before you do anything, go to the video options (there ought to be four of them), under one of them (second one I think) is the option to turn VM or SVM on or off (a setting of "zero" is off). For God's sake turn this off. I think it says "VM level" or something. Anything that says "VM" needs to be set to zero.
Now, to center the picture, I think you'll want the very top menu at the start of the service menu. One is horizontal something and the other is vertical something. BTW, it helps to have a test pattern for overscan when doing this. Do you own a copy of Digital Video Essentials? You should. Again, write down settings before you change them, so if you screw up you can fix it. To save your settings, keep hitting menu until you're back to the first screen, and hit mute twice. Then turn your tv off and back on. After using the service menu, my tv is always put in "dynamic" picture mode. Never, ever, ever use this mode. It will make the picture way too bright and kill your tv before its time. Use DVE or another calibration DVD to get the settings right on your tv.
BTW, you can also correct overscan in the service menu, but I wouldn't push it lower than 5%.
Mar 10, 2008 | Akai PTH5498 54" Rear Projection...
Using Hitachi's 53SDX89BA High-def settings w/ HD-DVD
look at these see if this helps
http://www.hdtvoice.com/voice/showthread.php?t=16973
http://www.hdtvoice.com/voice/showthread.php?t=8721
Most HDTVs cannot properly stretch incoming HD signals, however, if the programme is true HD, you should not much of the image off-screen - most new HDTVs have about 2% overscan and the tickers should be on screen when watched in the appropriate stretch mode.
See:
http://www.hdtvoice.com/voice/showthread.php?t=1044 and
http://www.hdtvoice.com/voice/showthread.php?t=1052
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Sony WEGA KV-27FS100 picture size
hi there, you may have a power supply section trouble, check the biggest electrolytic capacitor in the power supply, the rectifier diode, the regulator, and check for some cold solder, do some test, there is a part to be repalced. ty
Dec 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Panasonic PT-65WX51 65" Rear Projection Television Logo
203 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
