Question about Hitachi 50V500 50 in. HD-Ready LCD Television
No controls I have the LCD 50" tv. None of the buttons on the front of the tv work. The only button that works is the power button. The remote doesn't even work. I have the original remote which I have been using and also I programmed my cable remote to the tv and both have been working fine. 1 day they just stopped working. I have a little girl so I'm hoping she didn't lock it somehow. I have no idea what's wrong. Picture and sound are awesome, i just can't change the volume, channel, etc....
    Scholar:
  • 146 Answers
This should be easy to fix. The first thing is to check the buttons. Make sure that the buttons ar not pushed in and they work. What I meen is that when you push a button make sure it makes a cliking noise when you push it and releas it. If it dose not that is your problem. If they all work, Unplug the tv for 30 min. then plug it back in. It should work after that. If the remote dose not work after unplugging the set, you may have internal problems
Posted on Mar 15, 2008
I cant figure out how to put the tv on video 1
With the remote in TV mode, the input button on the remote should change the source (TV, AV1, etc. depending on the TV).
If the input button doesn't work, try a different code for your TV manufacturer. A code that controls the basic functions of the remote may not control the full set of functions of the TV. For some TVs, you can change the source from within the Menu. (It depends on the TV. I didn't notice if there was a Menu button that will open the TV menu on the RCA RCU600M.)
If none of the codes work, check if your TV has a Source or Input button on the unit. See if that button works.
If you have a different remote, please indicate the model.
I hope this helps.
Oct 13, 2011 | RCA RCU600M Remote Control
The tv was turned off with the remote 'set' button. Now, none of the power buttons including the one on the tv itself work to turn the tv on. Perplexed.
my remote control will not work after changing the battery on POLAROID ORIGINAL LCD FLU-2632 TV REMOTE CONTROL please help
Dec 12, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
Jul 11, 2017 | Emerson EWL3706 37 in. LCD Television
Hi! I have a problem with my sony bravia lcd tv model:kdl-46z4100. The only working buttons on a tv and a remote controller are power buttons. After turning on a tv you can only see a black screen with a...
You may have a case of a bad signal board. The clue was that your power button on the tv and remote are the only ones functioning. If the tv is still under warraty, call the service number to get help!
Nov 16, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Remote doesn't work with tv
Where did you buy your TV - Bestbuy? I have the remote you need and vice versa.
sader20@aol.com
Mar 29, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
Where is the eye for the remote on the TV????
Hi, remote sensor is located behind the front screen, if the remote doesn`t work as well (you didn`t say so I`m assuming it doesn`t) then you either have bad tact switches on the control board (the buttons on the front of the set) or the 5 volt line to the control board is missing, video-tek
Feb 03, 2009 | RCA P52937 52" Rear Projection Television
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
What's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Dec 30, 2008 | Yamaha HTR-6130 Receiver
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
106 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
