Question about Gateway 507GR PC Desktop
San Disk Memory Stick Pro Duo 2.0 GB
I guess that would help, Sorry.. I have a Sony Cybershot digital camera DSC-W80 and I tried to download pictures using the cable that came with the camera using th USB port on front of my Gateway 505 GR computer, all I could get was can not find the file or path, so I bought a 5-in-1 card reader from best buy couldn't get it to work either, so when I took the card reader back the employee said something about a default blocking something couldn't figure that out either. all I want to do is download my pictures from memory stick to my computer. Please Help Frustrated in Napa
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
Is its reading from camera are you watching your pictures from camera if yes what the error is showing when you are opening and it which company memory stick and what operating system it support give me the memory stick details
Posted on Mar 16, 2008
SOURCE:
Will sony cybershot dsc w110 support sdhc card
No, the DSC-W110 does not support SDHC cards. You have to stay with Memory Stick Pro Duos.
Jul 26, 2012 | Sony Cyber-shot DSC-W110 Digital Camera
Can sony digital camera dsc w 80 support 4 gb memory card pro duo
Yes, DSC-W80 manual says it supports "Memory Stick Duo" up to 8Gb, but there is also a comment that movies with the size set to 640[fine] can only be stored on a "Memory Stick Pro Duo" so therefore they must be compatible.
http://www.docs.sony.com/release/DSCW80.pdf
Mar 23, 2011 | Cameras
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
CAN I UPLOAD PICS FROM MY SONY CYBERSHOT W55 USING A SANDISK??
what do you mean nothing happens???
the memory stick pro duo should fit right into the sony cybershot....
if your struggling to load your photos onto your computer buy a universal memory card reader!
you should try and use a memory stick in a camera that needs an sd though!
Oct 16, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot dsc w80
One way is when you download them to the computer. When you first insert your media card (Memory Stick Pro Duo?), it should prompt you as to what you want it to do. "Do Nothing" reply.
Then open "my computer" from the start menu. When you are looking at your images, highlight them all and "Cut". Then paste them to a folder in "my pictures" and it should clear your camera.
Good Luck! Ed
Feb 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Computer doesn't recognise memory stick
well you could check if your media drive is compatible with memory stick duo/pro duo or update the drivers for it . or try something like going into its properties and click the tab called recording and select enable cd recording on this drive (if that renders your dvd drive inaccessible you can change the other drive(inaccessible drive) to that setting).
Oct 29, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Open Questions:
24X7 Roadrunner Email Number*+1*{855~536~5666}.*'-Roadrunner Email Number Roadrunner Email is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Roadrunner Email email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Roadrunner Email support number When you are using the Roadrunner Email for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Roadrunner Email support number and ask for the help. Once you dial the Roadrunner Email customer support number, you come in contact with a team of experts at the Roadrunner Email customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Roadrunner Email support phone number will help you with that simply and quickly. This is Roadrunner Email's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Roadrunner Email agent. Features of Roadrunner Email support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Roadrunner Email customer support phone number. Here are some of the features of customer service: The Roadrunner Email customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Roadrunner Email customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Roadrunner Email provides you the facility of Roadrunner Email support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Roadrunner Email. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Roadrunner Email Customer support number team.
Oct 18, 2019 | HIS Computers & Internet
Amazon Prime refund @#{1^845*48I*1722-}-Phone Number pochinki Amazon Prime is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Amazon Prime email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Amazon Prime support number When you are using the Amazon Prime for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Amazon Prime support number and ask for the help. Once you dial the Amazon Prime customer support number, you come in contact with a team of experts at the Amazon Prime customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Amazon Prime support phone number will help you with that simply and quickly. This is Amazon Prime's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon Prime agent. Features of Amazon Prime support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Amazon Prime customer support phone number. Here are some of the features of customer service: The Amazon Prime customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Amazon Prime customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Amazon Prime provides you the facility of Amazon Prime support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Amazon Prime. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Amazon Prime Customer support number team.
See all Gateway 507GR PC Desktop Questions
Gateway 507GR PC Desktop Logo
77 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
