Back to:
Tags:
Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1185 nylon strap behind print cartridges...
posted by tomhotmail on Mar 15, 2008
I see where this is to reattach at either end of the carriage, but I can't feed it through behind the print cartridges correctly - there is too much slack remaining.
Is there a picture or manual I can download that shows how to thread this nylon strap behind the printer cartidges?
What is its function?
Thanks, Tom
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 16, 2008
Not Rated (0)
Jarko
Rank:Guide Guide
Rating: 85%, 9 votes
It is so called encoder stip. It helps to determine the carrier position. ... and the view from behind
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Lexmark x1185 nylon strap behind print cartridges fell off:
I don't want to Accept this solution
Can you Help with these Printers problems?
I put in a new ink cartridge and cleaned the head but it...
some material was dropped inside the printer through the...
one of the little plastic inserts on the paper support is...
solved my problem now can print as always
i download my lexmarkx1100 series cd and it took but when...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
