Question about HP Pavilion dv6000z Notebook
Hp black screen white letters,reboot devices
  • Mel Balsamo
    Mel Balsamo May 11, 2010
    can you please post here the texts displayed on the black screen?
  • i need more information....
  • 24 Answers
Re-install window on your computer.
Posted on Mar 16, 2008
How to reboot my toshiba sat r llite C15 C1310 windows 10 screen is black with white letter saying reboot
Hold in the power key until the Laptop switches off
Press Power key to switch back on
Jan 29, 2017 | Toshiba Computers & Internet
Black screen with white letters reading "REBOOT AND SELECT PROPER BOOT DEVICE"
Misty here is what I would do:
1.Start the computer in safe mode.
2. update drivers. I go into Slim Driver - a free prog. and scan the system to see if ok or need updates.
3. once updated, reboot the system normally - any change? GL
Feb 01, 2014 | Dell Inspiron M5030 Laptop
On my other computer i have a black screen that says bootmgr is missing what can i do to get it back to working
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 02, 2012 | HP Pavilion ze4420us Notebook
I can't install any OS. it says BOOTMGR is
You will need an operating System Disk or Repair disk because you need to get to a Dos Command Prompt (black screen with white lettering) and type the commands below. Press ENTER after each command.
bootrec.exe /fixmbr
Reboot and see if the problem is solved. If not, run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 01, 2012 | HP Computers & Internet
My PC is not rebooting. It reads on the black screen in white letters "Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key." What would I do next to...
The computer is trying to boot but it can't access the hard disc drive with the operating system on it to boot up. Make sure the hard disc drive is properly connect to the motherboard. If it is properly connected then it is possible your hdd has failed and needs to be replaced and the operating system reinstalled. Another thing you can try is determining the maker of your hard disc drive and download thier utility from their website to run on the hdd to try and repair it.
hope this helps
regards
djbr1ck
May 12, 2011 | ASUS M4N68TM Motherboard
Just bought an asus laptop k50c series and when try to boot it it gives me a message "Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key" (in white...
Did you buy the notebook with an operating system (Windows) preinstalled?
Sometimes you just get the hardware and need to install the operating systems yourself.
Dec 28, 2010 | Computers & Internet
Need recovery disk
you can download it for 4.99 or call compaq service to order
Nov 23, 2010 | Compaq Presario 700 470024-192 Notebook
How do I clean the print heads? My black ink will
  1. Load unused, plain white letter or A4 sized paper into the tray.
  2. Open HP Solution Center:
    • Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
    • Windows Vista: Click the Windows icon, click All Programs , click HP , and then click HP Solution Center
HP Solution Center opens.
  1. Click Settings.
  2. Under Print Settings , click Printer Toolbox . The Printer Toolbox opens in a new window.
  3. Click the Device Services tab.
  4. Click Clean the Printhead .
  5. Follow the prompts on the screen, and then click Done .
May 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
My gateway 7330 will not reboot.white letters and black screen er
format your system and re install Windows,
this is master boot problem.
Jun 30, 2009 | Gateway 7330GZ Notebook
HP Pavilion dv6000z Notebook Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
