Question about Sub-Zero Bottom Freezer Refrigerator
Icemaker water does not go through tube to icemaker. I replaced filter still does not work.
    Problem Solver:
  • 8 Answers
Make sure the Tube to the Icemaker is Defrosted... got to make sure it is clear from ice. you might have to replace the Water Valve.
Posted on Apr 15, 2008
  • 770 Answers
Check the water inlet valve in the rear of the refrigerator/// do you have a water dispenser in the door?? if so switch the wires and see if the im then fills when pressing the water disp button
Posted on Mar 15, 2008
ICE MAKER NOT WORKING
Good day!!!!
The water filter may be plugged with sediment, or you may have low water pressure. The water pressure for icemakers needs to be at least 40 psi, and up to about 120 psi for proper operation. Water filters need to be changed every six months. If you would like to test your water pressure, we have an Icemaker Water Flow Tester available from our website. This will help you to determine if the water pressure at the supply line is high enough for the icemaker to function properly. To determine if your filter is plugged, look for water both before and after the filter. It may be hard to determine if there is water flowing through the filter. Sometimes it is necessary to pull the filter out of the feed line to see if water is flowing from the exit of the filter into the refrigerator or freezer. You can do this over a bucket to catch any dripping water. Some models have a filter bypass plug to help determine if the filter is clogged. If so, you would remove the filter and replace it with the filter bypass plug. Now test your water flow.
If your refrigerator has a water dispenser, you can hold a large cup or glass under it for 20 seconds. You should have poured about 13-14 oz. of water in that 20 seconds. If the amount is less, try removing the filter and bypassing it. If you now get the 13-14 oz. of water, the filter was clogged and it's time to replace it. If not, you have low water pressure in the line, and your icemaker may not work properly.
On occasion, the water inlet tube will freeze where it enters the icemaker. This can happen because the water is dripping slowly, or the freezer is just set too cold. A hair blow dryer can be used to thaw this, but be careful around the plastic tubing. You don't want it to crack or deform. You may want to turn the thermostat up a little bit if this is a regular occurrence. If you have a constant, regular drip, you may want to invest in a new water fill valve.
Another reason that your icemaker may not be making ice is the bail arm along the side of the icemaker. This arm must be in the lowered position for the icemaker to operate. If the arm is stuck up, it has shut the unit off. This is a safety feature of the unit. Normally, if there's too much ice in the bin, the arm will get stuck in the raised position and keep any more water from entering the icemaker. You must lower the arm to begin making more ice.
I hope this solution will be helpful...
Thanks for using fixya and don't forget to rate and write a testimonial if it is work..
Aug 31, 2011 | Refrigerators
Replaced water filter on my Frigedaire refrigerator and it is leaking where the filter is it is making ice when the bar is raised for no more ice it does not lead but when the bar is down to make ice is...
The problem there is going to be one of 2 related causes.
The tube in the back of the icemaker where the water enters it is partially frozen and when the water comes into the icemaker some of it is spraying into the bin instead of filling into the icemaker.Remove the icemaker and check and thaw that tube.
That tube is out of place so once again instead of water filling into icemaker correctly some of it is running into ice bucket instead of icemaker.
Gene
Aug 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
Kitchenaid refridgerator/freezer/icemaker model KBFS5ET5500 EVERYTHING WORKS BUT THE ICE MAKER...JUST QUIT. THERE DOES NOT SEEM TO BE A SHUTOFF VALVE AT THE BACK OF THE FRIDGE. I AM LOOKING TO SEE IF THE...
Hello Raymond,
In a most of cases if the filter were clogged it would affect BOTH the icemaker and the in door water dispenser,its never a bad idea to replace espically if they is a foul odor or taste in the ice or water. The water valve on the back is going to the most likely problem if the in door dispenser works yet the icemaker does not,a lot of times when the water valve is bad when its supposed to be fully closed cutting all water flow into icemaker it stays open a wee bit allowing water to seep through it causing the hose that connects to it ,running up the back wall into the icemaker to freeze up at the top where the tube enters into the freezer,that tube needs to be thawed, and to prevent it from freezing in the future the water valve needs to be replaced.
Goodluck,i hope this helps you to fix your icemaker,
Gene
Aug 09, 2011 | KitchenAid Superba Architect KSCS25INSS...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker not getting water. I came home to find water all over the floor from my refrigerator. I turned the water supply off in back of the unit and a couple days later started investigating. Changed the...
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 18, 2009 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid Icemaker does nothing. Ref. Mod.kscs25Inssoo
This also happened after I changed the water filter. The small black rubber tube that fills the tray was plugged with ice. Instead of hot wash cloths I used a hair drier for a couple of minutes.
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker won't fill with water
If you would like a repair manual for your refrigerator, you can get one here. These are helpful to have in case you have other issues with the fridge.
Thanks
Sep 29, 2008 | Samsung RS2630WW Side by Side Refrigerator
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Icemaker does not work
Hello Netmindr32,
You will need to replace your inlet valve. The problem is the water is slowly leaking into your icemaker fill line and freezing up. You will have a double inlet valve and the line going to your dispencer may be working fine but the one going to the icemaker is not sealing off. Be sure to defrost all the ice out after replacing the inlet valve. And please allow several cycles of your icemaker before it makes its first batch. It can take 2-3 cycles to fill lines and filters depending on your model. Lots of luck to you and please let me know if this helped you. Mca0824@aol.com
Apr 30, 2008 | Refrigerators
Sub-Zero Bottom Freezer Refrigerator Logo
80 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
