Sa-g90 receiver goes into overload and stops playing.
  • DanceAsIf May 26, 2008
    My Technics SA-EX800 will overload when I put a medium load on it and stops playing. I tried different amp speakers and that doesn't seem to resolve the problem.
Mine does that also. The cooling fan in the back is not working properly. It only runs when a certain load is placed on it. Sometimes it doesn't kick in and you get the overload. I can't figure out why. For some strange reason, adding a couple foot of wire to the antenna connection helped.
Posted on Aug 20, 2008
Technics sa-dx1050 overload
if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
Jul 23, 2012 | Technics SA-DX1050 Receiver
Overload on Receiver-SA-HE200
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} you many have a fraid wire or if you playing the unit to loud and overload the amp this may cause it to go to protect. Also is the the receiver properly vented. If it get to warm the receiver will also go into the protect mode. hope this helps
May 25, 2010 | Panasonic SA-HE200 Receiver
Ihave a technics reciever model sa-g90 it plays then it trips and shows overload. what should i replace?
Check out the power supply parts first. Then check out the main amp section (on the heatsink).
Look out for burnt or damaged parts. If it uses transistors and you have a ohm meter, test them for shorts. IE one probe on one leg and the other probe on another leg of the transistor. If you get the meter behaving like the probes were touching one leg it's shorted.
Jan 13, 2010 | Audio Players & Recorders
Overload on sagx550 technics
Disconnect all speakers at the receiver then turn it back on. If it still goes into "overload" you need to have the unit serviced. If it stays on, post a comment and I can walk you thru troubleshooting your system.
Dec 22, 2009 | Technics SA-DX750 Receiver
I have a Technics SA-G90 AV Receiver. I have all the original speakers and they still sound great. I was wondering if there was any way to buy a subwoofer and hook it up to this receiver. I know this...
Sight unseen, any powered subwoofer can be hooked to any older gear. Just run a pair from an unused Tape Output to the Sub (you might have to get a Y-cable to make it a mono input). You might not be able to match levels, though, so you sub amp should have some kind of volume control.
Nov 05, 2009 | Audio Players & Recorders
How to fix a home theatre receiver
do you have the volume turned up all the way? do you have the sub turned up all the way? thats probably why its overlading.
Mar 24, 2009 | Technics SA-EX320 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Receiver overload problem
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
Dan
May 23, 2008 | Technics SA-DX930 Receiver
Technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Nov 30, 2007 | Technics SA-EX300 Receiver
444 people viewed this question
 Grubhead
Grubhead
