Question about Lowrance LCX-19C GPS Receiver
Lowrance LCX-19C GPS Receiver Problem
After being turned on after a few moments the screen begins to get erratic and starts to show inaccurate depths or the screen almost goes black and starts to show 1 or 2 feet of water. It didnt always do this. I tried to isolate the power going to the unit by running directly to the batt. and shutting down the motor. Curious how to find out what is at fault ( unit, trans., trans. cable, electrical or something with way the trans. is mounted). It worked fine for 2 summers then went out to the dock one day and seems to be acting funny.
Any help would be greatly appreciated. Also wanted to know if I could send the unit to lowrance to have it tested.
  • 1 more comment
  • jburns001 Mar 24, 2008
    Very helpful thankyou
  • Trimix Jun 16, 2008
    I have the same problem. I have used the unit for a few years and all
    was fine until last month. I tried the suggestion you got, but it did
    not resolve the problem. Have you sent your unit to Lowrance? If so,
    was it fixed and how much did it cost?
    Thank you very much!
  • newimage1 Jun 19, 2008
    similar problem with lcx 25c. sonar will randomly work and then cut out, digital depth reads 2.2 / 2.3. screen fills up with yellow/black/blue. the sonar will cut out at all different speeds. tried transducer angle,cleaned connections,shut off all other power, soft reset of unit. i plugged in my other lowrance and had the same problem so i assume it is cables or transducer. no visible signs of scratches on the transducer.
    any suggestions?
    Novelist:
  • 113 Answers
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Posted on Mar 17, 2008
6ya staff
SOURCE:
My Mark 4 sometimes shows incorrect depths. The transducer has not moved and no problem with electrical. One point it is working fine, the screen then runs multiple vertical lines and the depth chan
Take note if when the vertical lines appear on the screen if the depth numbers begin to flash. If this is the case then the transducer has lost bottom contact and the unit is trying to reacquire bottom contact. If the transducer is parallel to the bottom of the lake while your boat is not moving then, the next time you have it on the trailer, turn your unit on and go listen and or feel the transducer to see if you can hear and or feel the tick or sonar ping. If you can't your transducer may be faulty. If the loss of bottom contact occurs when you are moving it will happen at a certain speed. This is the result of air bubbles passing under the transducer and disrupting the sonar signal causing loss of bottom contact.
Sep 19, 2014 | Lowrance Mark 4 Chartplotter/fishfinder...
The screen goes dark after a few seconds of it being turned on
There is nothing you can do about it by yourself. Consult some qualified technician or service center
Dec 21, 2013 | LG 42LH30 42 in. LCD TV
Aspire 5349 Windows 7
harry not a joke but this happen many a times.
dont know d reasons. but try with win xp.
Format c drive properly.
then if you want upgrade with win7..
Dec 17, 2012 | Acer Computers & Internet
Laptop goes blank on startup but still display logon screen
Have you upgraded the OS? At boot start tapping the F-2 key, do not wait for the Dell screen. Take a look at this forum:http://www.computing.net/answers/windows-95/dell-s-bios-startup-screen/85976.html
Nov 22, 2012 | Dell Inspiron Computers & Internet
Shows incorrect depth suddenly and Erratic displays
MY XD510c works fine then flashes 2.5 and fills the screen with black red blue white vertical lines...then after an amount of variable amount of time goes back to working for awhile
Jun 23, 2010 | Lowrance X510c 5" Screen Color 200 Khz...
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Bottom half of screen goes black
This is because full pixels of your TV is not getting invoked at the beginning .If you are able to view the picture as normal after 1 or 2 minutes, its fine.Else you need to call to service center and get this problem fixed.
Aug 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
Rca p52937sg
Hi, your vertical section is beginning to fail, from your description you have a few electrolytic capacitors that are beginning to go bad, the correct term is they are "leaky", the set can be fixed easily by a tech, not so easy for a layperson because you don`t have the service manual or a capacitor analyzer. NOT an expensive fix, tech will have to remove board, unsolder some caps, check them and replace the bad ones, do a little touch up solder work and set is good as new, any questions? feel free to ask away, if not Happy Holidays, BMW Rider
Dec 08, 2007 | RCA P52937 52" Rear Projection Television
Lowrance LCX-19C GPS Receiver Logo
789 people viewed this question
Top Lowrance GPS Experts
Jay Plesset
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
