Question about GPS
POLAROID MGM 0550 gps signal problem
My POLAROID MGM 0550 GPS keeps searching for a signal, but never finds one. Worked perfectly even in the car in the past, now gets no signal even outside the car. Anyone have any ideas.
2 Suggested Answers
  • 794 Answers
SOURCE: can you fix my polaroid
Hi danpro,
You may try to reset your system (Polaroid MGM 0550) to put it back into gps. You can follow the following steps I have below:
To reset GPS.
1. Go to navigation mode.
2. Press and hold the map button below the display for 5 seconds. Then the GPS resets.
3. Verify that the GPS system is turned on. Touch Menu, Map Options, Settings, GPS Signal.
Hope it helps.
Thank you for using Fixya.
Posted on Mar 25, 2011
Where do I find software to reload a Polaroid Mgx-0550 GPS Navigation and DVD Player?
Go to Polaris Page : www.polariswireless.com
But be careful to have latest antivirus and security program on your PC or Smartphone before clicking or tapping any links.
May 01, 2014 | Polaroid GPS
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
Can you fix my polaroid mgm 0550 gps that is now a microsoft windows ce can you turn it back into a gps
Hi danpro,
To reset GPS.
Hope it helps.
Mar 25, 2011 | GPS
Polaroid GPS Model # 0550, Will not go into GPS mode. Shows Windows CE on the screen.
Your operating software has become corrupted, the only way to fix this is to contact support for the GPS at Polariod and see if u can format the GPS and relaod the software
Mar 08, 2010 | GPS
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
Wont pick up a signal.
Try updating with the latest GPSfix updating via the tomtom home software
Aug 01, 2009 | Tomtom XL 330S GPS Receiver
My tomtom cant find any satellites and keeps saying waiting on valid gps signal......
check the port is set to 8
not sure if your model has GPS search wher it finds the port and vbaude automativcally, if it does use it and see if that fixes it if not
your battery is too low
you have a damaged SIIRF chip and that is expensive to repair
Jun 01, 2009 | Tomtom ONE GPS Receiver
My tomtom keeps saying waiting for gps signal. was working perfectly, now wont pick up signal wherever we are
go to tomtom website ----> support ---->select product,
in the search box type in "lose signal",
click the "2. Updated - No GPS signal"
then follow instructions.
if it help rate the Solution Please
21/Apr/09
Apr 20, 2009 | GPS
My Garmin has stopped finding destinations - just says "Searching for Satellite)+
I had the same problem with my Nuvi 310. Found a solution in here that works. Here's a copy of the advice.....note you will need to get in the car and set it for a destination and go. 5-10 mins later the Garmin Nuvi will lose the satellites, but don't adjust it it, leave it on and keep going. Eventually after about an hour it will right itself, pick up the satellites and evrything will be back to normal.
Here's the advice:
happy2surf
Rank: Apprentice
Rating: 81%, 49 votes
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching!
The unit appeared to have "stuck" in this acquiring mode. The following worked for me:
1) open the GPS antenna
2) press the bottom left screen while holding the power button to turn the unit on
3) enter maintenace mode
4) select diagnostics
5) clear error report, do NOT clear any user data
6) restart unit the usual way
My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Dec 05, 2007 | Garmin nuvi 350 GPS Receiver
I cannot acquire satellites signal. What to do ?
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
147 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
