Question about Motorola Talkabout SX700 2-Way Radio
Garbled output from one SX700 radio
I have a pair of Motorola SX700 two way radios. One of them ("good one") seems to work just fine. The other one ("bad one") does not.
The good one transmits and receives normally and this is confirmed by its ability to interact with other two way radios on the same channel.
The bad one transmits but the signal is garbled and cuts out most of the time. It does, however, receive signals clearly.
Any ideas about what could be happening or how to fix the bad unit?
  • Reallyfubard Mar 15, 2008
    Thanks for this comment. Is there a way to fix the conductor coils or is the unit beyond repair? About the range, I tested the unit at close distances (within a metre or few) and at much greater distances (up to over a kilometre). The results were identical. Does that help?
  • 796 Answers
THE INDUCTOR COILS IS THE PROBLEM...
IF YOU HAVE THE INDUCTOR COILS EVEN DISTURBED TO ABOUT 1MM THE RANGE VARIES...
MAY BE THIS IS CAUSING THE PROBLEM
Posted on Mar 15, 2008
    Genius:
  • 1,665 Answers
Hi have a nice day!
  • Anonymous Mar 15, 2008
    It seems to have cold solders at printed circuit board or an ic problem. I dont think that a doityourself repair is possible.
    I suggest to take it to an authorized work shop for sure.
    Try also motorola email support
SOURCE:
What are the ctcss frequencies?
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
May 06, 2014 | Motorola Talkabout SX700 2-Way Radio
1 of my sx700 is not responding
I would suggest taking the radios back to a very basic programming with the interference eliminator set to zero or off, and any special features shut off. This would enclude Qt filter, call tones, iVox/Vox, vibra call, keypad tones, roger beep, enhanced scan, weather, etc. Set both radios to the same frequency and see if they work. If not, try switching the rechargeable battery from one radio to the other. Does the problem move to the other radio? If so, you need a battery. If neither of these helps, you likely need to replace the radio.
User guide: http://www.giantintl.com/ContentManage-new/manuals/Moto/SX700.pdf
Best regards.
Sep 28, 2012 | Motorola Talkabout SX700 2-Way Radio
What is the frequency band for sx700
The Motorola talkabout SX700 2-Way Radio is capable of operating on GMRS/FRS bands.
Here are the Family Radio Service and General Mobile Radio Service frequencies: http://en.wikipedia.org/wiki/General_Mobile_Radio_Service#Frequency_chart http://en.wikipedia.org/wiki/Family_Radio_Service#List_of_FRS_channels
Aug 26, 2011 | Motorola Talkabout SX700 2-Way Radio
Motorola SX700 battery drainage w/tactical mike
It is likely the mic set you are using is not made for the SX700 radio, and is drawing too much power from the radio. Some audio accessories draw more power than others. It is possible your mic set is intended for a professional model radio which would supply more power to the device. You should check with Motorola to see if they have a mic set similar to go with your SX700 radio. Here is a link to their online store: http://www.store.motorola.com/mot/en/US/adirect/motorola;jsessionid=130652F39955D9E9CA94908C45C73822.mot3?cmd=catDisplayStyle&entryPoint=adirect&catKey=601560&messageType=catDisplayStyle
Oct 18, 2009 | Motorola SX700R 12-Mile FRS/GMRS Radio...
I have 2 Motorola SX700 the black one static when i turn it on
Here are a few troubleshooting ideas. 1) Check your battery installation, and clean the contacts both of the radio and battery with a pencil eraser. 2) Install fresh batteries (or swap the rechargeable from your other unit) to see if it is a battery related issue. Static is a sign of a bad or low battery. 3) Turn your CODE on to a setting and continue using the radios as normal with a CODE to block the noise. It is possible due to dropage the radio may be more sensitive to RF in your enviroment than the other radio now. It could have a possible hairline crack in the componet board, or a cracked/damaged speaker.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/SX700.pdf
Best regards.
Sep 14, 2009 | Radio Communications
Motorola talkabout sx700
Check your "code" setting. You may be on the same channel, but different codes. The code is the smaller number. Check your owners manual if you have one for resetting the radio to the factory default settings. This will clear any programming issues.
Aug 15, 2008 | Motorola Talkabout SX700 2-Way Radio
SX700 and T5522 talkabouts
Hello Walvis,
Based on a quick web search the Motorola SX700 appears to be a Family Radio Service unit for use in the USA and the Motorola T5522 appears to be PMR446 radio for use in the UK. While the radios are similiar, they don't operate on the same frequencies so they won't be able to communicate with eachother. Because both FRS and PMR446 are very similiar, Motorola often markets versions of the same radio (with slightly different model numbers) for each service.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Motorola Talkabout SX700 2-Way Radio
SX700 2-way radio garbled
ok sounds like there is a lose connection in the airal or the speaker so it would probably need to be repaired
your best option is to take it to a electronics repair centre near you that specialise in motorola equipment
Mar 18, 2008 | Motorola Talkabout SX700 2-Way Radio
Sx700 charger
try useing phone charger as long as jack will fit yours
Oct 16, 2007 | Motorola Talkabout SX700 2-Way Radio
Motorola Talkabout  SX700 2-Way Radio Logo
149 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
