Question about Sharp AR-5316 Advanced Digital Imager Copier
Solution hi it display F and 5 after warming up and refuse to get ready for copying. l need solution for this problem
I thick the copy lamp is flickering it can be solved by clening white reference in platen glass if still persists press ash,interupt,c,interupt and enter 14 then press green colred start key.
Posted on Apr 23, 2008
My konica minolta c250 is not ready but displaying warming up for a very long time and it did not ready still yet
Warming up means that the copier is not getting hot enough in fuser section, Secondly during that time certain internal house chores are done by the copier to prepare it for READY TO COPY. Are all the image units and toner cartridge OEM!!!??? second has each image unit and toner properly shaking ensure toner in toner cartridges and developer in the image units is spread evenly across each pull each out. shake side ways to ensure spread evenly, last time toner full was run nd gradation adjustments run ?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 02, 2015 | Konica Minolta Konica Bizhub C250 Color...
Please how do I clear the H 4 display on my Sharp AL 2020 copier machine
Content
Heat roller low temperature detection
Detail
When the fusing temperature is lower than
150C after 55sec from the start of warming
up.
When the warming up complete temperature is
not reached in 30sec from reaching 150C.
100C after 20sec from ready start.
145C when printing."
Cause
Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control PWB abnormality
Check and remedy
Use SIM 5-02 to check the heater lamp blinking
operation.
When the lamp blinks normally.
Check the thermistor and its harness.
Check the thermistor input circuit on the control
PWB.
When the lamp does not light up.
Check for disconnection of the heater lamp and
the thermostat. Check the interlock switch.
Check the power PWB and the lamp control
circuit on the MCU PWB.
Use SIM 14 to clear the self diagnostic display.
Mar 06, 2013 | Office Equipment & Supplies
Need a copy of the instructions for using this product
hi which model and brand is your vacuum cleaner please specify the correct brand name and model number to ensure that u get the correct copy of the instructions for using ur product without any damage we r ready to help u
with warm regards - bonefirediv
Mar 25, 2011 | Vacuums
When Copying or printing the paper does not feed
open the front cover pull out the cartridge and you see paper feed roller it is rubber. Clean paper feed roller with cloth and water or alcohol.
Jan 24, 2011 | Samsung SCX 4521F All-In-One Laser Printer
My printer still prints, but make noise when the scanner lamp warms up. After that, the screen says, "Scanner Error 5". What's the problem?
Hi tatnle,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the enter and the * button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp 1800-334-5144.
Al
Eliteprintersolutions@gmail.com
Jul 15, 2010 | HP LaserJet 2840 All-In-One Printer
Infotec 5221 displays a E-5 symbol
E-codes (E1-E7)are displayed im the copy counter.To display both digits of the E code press the Enter key.When service call E5 conditions occur,they cannot be cleared by turning OFF/ON the main switch for safety reasons.Ehe following procedure must be performed to clear these service call condition:
Turn ON the main switch.
Turn DIP switch 101-1 ON and OFF.
Turn the main switch OFF and ON.
Code E 52 Fusing lamp warm up error.Causes:thermistor open,fusing lamp open,therofuse open,power supply/ac drive board defective.
Code 53 Fusing lamp overheat.Causes:thermistor short,power supply defective,main board defective.
Code 55 Fusing thermistor open.Causes:thermistor open,main board defective,power supply/ac drive board defective.
Aug 14, 2009 | Ricoh Office Equipment & Supplies
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Won't Copy - just "Warming Up" message
The solution to your problem can be found here. Enjoy!
Apr 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Canon CLC 2400
go into service mode and clear ram remember to copy the values before clearing or your dc controll is damage
Nov 29, 2007 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
