Question about Refrigerators
WILL NOT MAKE ICE. MAKES THE NOISE AND THE WATER SIDE WORKS.
    President:
  • Refrigerators Master
  • 2,651 Answers
Makes the noise??? like it trying to call for water noise???, if thats the case check, the inlet fill tube leading to the ice maker see if its frozen. obvoiusly thaw it out ifso.if theres no ice in there and the water line leading to the tube had no water in leds me to beiev that the valve itself is no good
Posted on Mar 15, 2008
SOURCE:
Ice maker was making noise then stopped working
you will have to access back of fridge to see if water hose is connected or may have come loose! I think has to do with water not entering ice cube tray. Noise was probably no water entering?
Apr 23, 2012 | Jenn-Air JCD2389G Side by Side...
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
No water to the ice maker
Check that the pipe that fills the ice maker is not iced up. Also check that the solenoid on the back (where the waterline hooks up) is making a humming noise when the ice maker calls for water.
Apr 30, 2010 | GE GSH22SGRSS Side by Side Refrigerator
Ice maker is not making ice. Water dispenser is working. It sounds like it is trying to make ice (clicking noise).
the first thing to check is the fill tube and make sure there is no frozen water blocking the tube.if there is no water blocking the tube then make sure you water fill valve is good you might have to replace the ice maker itself.
Feb 24, 2010 | Frigidaire PLHS237ZD Stainless Steel Side...
Fan makes noise on LG lsc26905tt. defrosted and
Sounds like ice is building up near the fan blades. Try defrosting it longer to melt out all the ice and see if that helps.
Nov 09, 2009 | LG LSC26905TT Side by Side Refrigerator
The ice maker is working alone, and makes a noise.
does it have a lever that you can lift up and turn it off since you are not using it to make ice.this will eliminate the noise which is trying to add water but you don't have the water line hooked up to it or your water solonoid is not letting water feed yhe ice maker tray. good luck,hope this works.
May 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker maker horrible noise when activated
take out your ice bucket and clear all frozen water out of it only cubes should be in there if you have had a drip for several weeks you may have a big chunk in there possibly wrapped around the screew
Feb 26, 2009 | Maytag MSD2456G Side by Side Refrigerator
Fridge: not making ice, no water in ice maker
look to the water inlet valve behind refrig sound like you got a frozen line, or a bad solenoid
Feb 19, 2008 | Refrigerators
ICE MAKER AND WATER SUPPLY DOES NOT WORK
I lifted the switch to turn ice maker off, left it like that for a couple of hours, then turned it back on. I checked it a couple of hours later....Making ice now....
Thanks pete5runner!!!
Feb 18, 2008 | Refrigerators
GE Model TFF24RWC Side By Side Ice/Water not Dispensing
I had that issue and a myriad of other issues with my GE side by side fridge. I replaced the control panel $100 and all three problems I had went away immediately.
1. Ice and water dispenser quit working
2. Howling noise 12 hours out of the day
3. Clicking noise
Jan 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
134 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
