Question about Philips WACS700 Shelf System
WAC700 Wireless music center
Plug it into mains and screen turns on, I get message saying Booting up Please wait, but thats all it seems to do. i cant actualy turn the machine on with the standbye-on button, please help
  • 476 Answers
This can be caused by either corrupt firmware, or bad connection between the front panel and main unit.
The firmware can be restored as follows:
Unpluck the unit from the mains.
Press and hold [STOP] & [SOURCE]
Plug unit into mains.
Continue to hold the two buttons until the recovery message appears on screen.
If the progress bar doesn't move at all within 5 minutes, then this is not the problem.
This problem can also be caused by the ribbon cable connection between the front panel and the main unit. Sometimes the problem can be cured by disconnecting both ends of the cable.
The firmware should still be ok in this case.
There are multiple processors in the WACS700 unit, and the problem occurs when they can't talk to each other.
An authorised service agent should be able to sort the problem with a replacement cable.
Posted on Mar 17, 2008
Mine was the same all i did was reset to factory settings and my music was still there
Posted on Feb 17, 2011
Philipss music centre can't power up
If the center wont power up, then its the power supply thats the issue. If it turns on and the screen says " Booting please wait " and does nothing else then internal hard drive is at fault. Hope this helps.
Apr 22, 2014 | Philips WACS700 Shelf System
Phillips wac700 says booting up has not been used for a while
Just unplug the device from AC mains socket and replug it after 3 minutes and see whether it helps you. If not, a firware upgrade will be necessary. The supplied PC installer CD contains Media Manager [DMM] software. it will help you to upgrade for WAC700 center. For details see DMMs' help file. Refer to the manual CONNECT YOUR PC to learn how to install the software. OK.
Jan 16, 2012 | Philips WACS700 Shelf System
How do you connect an ipod or mp3 to the waC700 wireless music centre?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 20, 2011 | Audio Players & Recorders
When i try to go into my media center or use my ringtone,camera, or any audio it says please wait, refreshing media how do fix this annoying *** problem this has been going on for a week now plz...
try deleting some of the stuff you dont and music bog it down. You may even see a note that its reading the sim...once again, the processor is lagging.
Dec 05, 2009 | Motorola Mobility i776 Cell Phone
Connect my center wireless via my route to my pc, but i have no
If you open the CD contents in a folder and run the Setup in XP compatibility mode, and the software should work. <div><br /></div> <div>Good luck from there! I still can't get my PC to recognize the music center.</div>
Aug 02, 2009 | Philips WACS700 Shelf System
Streamiun Wac700 CENTER says can't connect to!
put units side by side and switch them both off. Plug in main unit, and using menu resort factory settings, then when it reboots, select language, and leave it there. Then connect the smaller unit and do the same thing (restore settings), they should then find each other.
Apr 27, 2009 | Philips WACS700 Shelf System
Bose lifestyle fault code 802
Here's what the Bose support website suggests.  Good Luck!
Messages displayed during a Music Information Update
Messages may appear on your media center display during a Music Information Update. If you see a message with instructions to call Bose, and a three-digit code such as "Error Code 802" or "Failed 172" while performing a Music Information Update, it does not necessarily mean there's something wrong with the system. Performing a media center reset and installing the update again may address the issue.
To reset your media center, follow these steps:
  1. Turn the media center off. Wait two minutes
  2. Unplug the power cord from the media center. Wait 30 seconds
  3. Reconnect the power cord
  4. Wait until "Bose Lifestyle" disappears from the screen
Note: After a reset, you will need to wait several minutes before playing stored music (3 to 20 minutes, depending on how many CDs have been stored). All other sources will be available immediately after the system powers up.
If you have any additional questions about these messages, please contactBose® Technical Support or call 1-800-278-1281.
Dec 01, 2008 | Audio Players & Recorders
WACS700/05 Wireless Music Centre will not Boot up
tried to hold source and stop got message firmware damaged retriving copy from backup. power turn off, hold down source only power on comes up booting up please wait but in the lite up mode, 30 seconds later everything back on
Aug 20, 2007 | Philips WACS700 Shelf System
Philips WACS700 Shelf System Logo
1,013 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
