Question about GE Spacemaker JVM1640SJ Microwave Oven
LCD not working
Is it easy to replace the LCD display on a GE Spacemaker microwave or does this require a service call. The display slowly started to fade and now it is totally dark. Thanks.
  • Strobes Mar 18, 2008
    Thank you very much for your advice. That was exactly what I was looking for.
    Scott
  • GE Master
  • 9,174 Answers
In most cases, these are VFD type not LCD type. In any case, when a VFD fades over time, that is aging.
Unfortunately, GE does not make the VFD displays available as a separate part, so the only option is to replace the entire "smart board". And they can be expensive at times. But if you do it yourself, you save a lot on labor.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
6ya staff
SOURCE:
The plastic door handle on our GE Spacemaker XL microwave oven (JVM1341WW 002) broke. I ordered and now have replacement handle and screws onhand. How do I gain access to inside of the door to replace...
I do not know your unit specifically but a lot of them you have to start by, slowly, from the inside of the door, lifting up on the choke that runs along the outer inside edge of the door. It looks like a plastic trim part about 3/4 of an inch wide. You slowly work around the whole door unit you get it popped out. a butter knife or steak knife works pretty well . I just use a small flat head screw driver The screws for the handle are behind that choke seal. Usually 2 Phillips head screws. The choke part just snaps in place and has no screws to put it back, just push back in place and you will hear it snap as you go. Be careful the plastic tabs are easy to break off
Aug 19, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker II clock not working (1994)
Are you working with the owner's manual?
You can download GE owner's manuals and installation instructions here.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave turntable no longer turns. Microwave still heats, but turntable has stopped working. What are likely causes? And is this something I can attempt to fix myself?
This is a common problem the turntable motor has failed, it can be replaced.. but Microwaves are VERY dangerous. Due to the enormous energy stored in the main Capacitor, this MUST be discharged to earth B4 attempting any repairs. apart from that though should be easy enough. I do recommend a reputable service center/man tho.
Jan 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating food
It's most likely the Magnetron. The are not very easy to install and quite expensive. Older models magnetrons cost about 80 bucks from GE. It's probably not something you would want to try and repair yourself. Call a GE service person.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE PROFILE SPACEMAKER P/NO 8114-334-730 MICROWAVE TOTALLY DEAD!
Sorry Seanna, but I have been getting a lot of problems with GE microwaves. You can call customer care at 800-432-2737, but out-of-warranty repairs are very expensive. Sounds like your problem may be door latch circuitry which requires service. If your unit is old, consider replacing it as prices are very reasonable.
Ray
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stops running after 3-5 seconds
hade same problem upper door switch by past it microwave works
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
170 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
