Hi
Thanks
for using FixYa. If the dishwasher is draining properly and is working
perfectly fine then you'll need to open up the
Dishwasher and check the heating element as that could have gone bad. You can
get to the heating element from underneath by pulling the unit out and then
tilting it backwards. If its not draining properly then check whether
the drain is not clogged or blocked and the line is not kinked. Check all the
hoses for blockages & also clean the air gap. Has the disposer been
replaced recently? If so, chances are the knockout is still in place. Simply
remove the drain hose from the disposer, and knock out the plug. If the
disposer has not been replaced, try removing the drain hose from the disposer
and use a wet-dry vacuum (prepared for water, of course) to **** any water (and
hopefully anything else) from the drain line. Then reconnect the hose, and test
the unit. If you have checked the air gap and the drain hose and can’t locate the
problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution
if the issue is resolved or else revert for further assistance.
Thanks
Rylee
The vent is in the door and you need to remove the panel on the door. However, if you take the kick panel off the bottom, there should be a techincians guide attached to it and that shows all the tests etc that you can use to troubleshoot this.
