Question about GE Profile DPSR473EW Dryer
Dryer quits running but heating element stays one
I got up the other morning and went to pull some clothes out of the dryer and it was still hot inside. No one had run the dryer since the night before so it appears that the heating element stayed on all night even though the drum wasn't running. This happens on the autocare mode, I haven't noticed it on anything else.
Is this just a problem with the timer module? Or something deeper?
  • Anonymous Apr 24, 2008
    dryer shuts off but heating element stays on
  • daves_faves Jan 11, 2009
    I also have a GE dryer with the same problem. The heating element stays on after the drying cycle has stopped. The only way to turn the heating element off is to switch to a "no heat" setting. I discovered the problem this evening... the top of the dryer was almost too hot to touch.
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
SOURCE:
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer stay hot
It's very possible your element shorted to ground causing the element to get constant currant from the wall outlet if it was hot without running, if thats the case you need to replace the heating element.
Jan 15, 2014 | Dryers
Wont get hot and dry clothes
If the dryer runs the same as before except it will not get hot then check your heating element that is more than likely your problem.
Sep 04, 2012 | Maytag MDG6400 Atlantis Gas Dryer
HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
Jun 17, 2012 | Hoover Dryers
The dryer gets hot and then cuts off now it want even turn on I was wondering if it was the therma fuse, thermostat and the heat element that went wrong. E-mail address is [email protected]
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Mar 26, 2011 | Maytag PYE2300AY Electric Dryer
I have a roper dryer Model RES7646KQ2. While I
Sounds like thermal cut off fuse has blown. That is indicative of airflow obstruction somewhere either internally in the dryer or venting from dryer to outside v
Nov 15, 2017 | Roper REX4634KQ Electric Dryer
Our kenmore dryer wont get hot at all and it wont dry our clothes
SOUNDS LIKE YOUR HEATING ELEMENTS HAVE BURNT OUT AND YOU NEED TO REPLACE THEM.
Oct 23, 2009 | Kenmore 63942 Dryer
Dried some clothes the other night and when I went out to take the clothes out the next morning the dryer was hot on the top and in the back of the control panel. I unplugged the dryer and took the top...
More than likely, the motor centrifugal switch is stuck. You should be able to turn off the element with the timer control switch. If the timer switch is on and the dryer is not running, the element should be off, unless the motor contact is stuck closed. You will have to get to the motor and 'un stick' the contact.Its a bit tricky, you may need help.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 21, 2009 | Kenmore 62802 Electric Dryer
Dryer Overheating
your element should shut off when dryer is not running.their is a short somewhere.could be timer or even the motor switch.
Mar 11, 2009 | GE Spacemaker Washer and Dryer Electric...
GE clothes dryer,model DPXR483EA1WW
Well this morning I got up and pressed the start button on my dryer and it's been working eversince. Thank-you I will contact you if I have any more problems. Jessica
Jul 18, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
205 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
gbob59
Are you a GE Dryer Expert? Answer questions, earn points and help others
