Question about Hitachi 50SBX78B 50" Rear Projection Television
Lamp flickering my Hitachi 50SBX78B set is having a jumpy picture soon after startup. When my kids stamp their feet on the floor that stops it (not kidding!). Any idea what could be loose? if it's time for new bulbs, are they user replaceable and where is the best place to find them?
    Novelist:
    Scholar:
  • 96 Answers
Well jumping has nothing to do with lamp so called bulb.
You have what I would call a cold solder joint.
You're going to have to open the set and tap gently to see were it is comming from. If you know anything about soldering they you will know it is not that easy.
Once you think you have found the place were it seam's to be the place were it make's it jump more often, start again to make shure that's the spot and not the hole area.
Then remove the board and resolder,
Good luck
What About Bob
Timmins, ontario
Home of Shania Twain.
Posted on Mar 15, 2008
I have a Hitachi 50CX29B 50 in, got it used, it only turns on sometimes i think the power button is lose, and when on the picture flickers occasionaly, is this something that can be fixed easily
The first reason for this fault is the lamp itself, just about to expire.
Check the lamp and then if OK power the projector up with no signal. Does it flicker then? If it doesn't it is a signal lead or the signal itself, if it does suspect the lamp.
Jun 10, 2011 | Hitachi 50CX29B 50" Rear Projection...
Hitachi 50V715 power on/off problem
I would check to see if any of the fans stop turning or don't turn when set turns on. They do have sensors monitoring them and the set will shut down if they are not turning. I believe there are three fans around the chassis.
Hope this helps,
Skyassoc
Oct 23, 2009 | Hitachi 50V715 50" Rear Projection...
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
Hitachi 50SBX78B Horizontal lines and bow
John, Hitachi site is down at the moment, if you remove the clips on the front of the IC`s you will see the numbers of the convergence ic`s, and yes they are a pain to get out, they are probably stk 392-110`s if they are the originals, you`ll have to un-solder 36 pins total to get them out, check for burnt resistors in the general area of the ic`s and replace any that are burnt before turning the set on,be sure to order a tube of "heat sink compound" to apply to the back of the new IC`s, once on the set will probably still look poor, this is normal, run the set for minimum of 15 minutes then push the " magic focus button " inside the front door panel, after it has finished running magic focus it should look great, video-tek
Feb 08, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Heard a POP then no picture!
You need a new bulb, my tv did the same thing.
Dec 24, 2008 | Hitachi 46BX01B 46" Rear Projection...
JVC NV-50D500 Flickering
convergence board problems u will nedd replacment soon
plz do rate this post
Nov 30, 2008 | JVC AV-48WP30 48" Rear Projection...
Motorized sound and picture quality poor and jumpy
your husband is correct it is most likely your color wheel very common and it will effect the picture. what will happen soon is your tv will not turn on. The cost is two possiablities. color wheel replacement 225,00 part is 80,00 complete light engine in rear cases cost is 650.00 dollars . I hope this helps
thanks doctor video leadingedgeeletronics since 1987
May 04, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Owners manual
Click on Hitachi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Dec 24, 2007 | Hitachi 50SBX78B 50" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
