What kind of motor oil do i need for my 2003 bmw 325i? Mobil 0w-40, or mobil 5w-30? what do you recommend in summer and winter?
Use a 5/30 synthetic oil..its good for winter and summer.
Testimonial: "thanks for your answer"
30 or 40 is the difference betwwen summer and winter. You can run the thinner 30 weight in winter and 40 in summer. As for your answer, 5 W 30 all the time.
Testimonial: "thanks for the answer! very helpful."
A straight foreward 20/50 ---change oil every 6000miles and the oil filter every third oil change ,use the cheapest oil you can buy no need for that BRAND stuff ,supermarket special is best and if you can get a offer like buy two and get one free grab a load of it .Do it my way and the engine will last forever with none of that horrid brown stuff inside it that ends up coming loose and blocking the pick up pipe filter.Best buy is turbo diesel engine oil for all engines ,really stays clean inside with .
Testimonial: "great! thanks much."
What will let my bmw325i to get quick start
Go on e46fanatics and ask them. They love oil threads.
SOURCE: i have a bmw 2003
You can try a thicker oil. But it sounds like a valve lifter may be going bad. Try an additive to see if it makes any difference. May be that the pump did not pump the oil right away. Run the car for a while . See how it sounds.If the ticking gets worse it is probobly one of the lifters.
SOURCE: how to replace rear shocks on 2003 bmw 325i
You have to take the trunk liners off of both sides. There will be 3 13mm nuts on each side for the shocks, and under the car is a 16 or 17mm bolt that has to be removed. I hope this helps.
SOURCE: abs brake light dsc on 2003 bmw 325i
many reasons for this. A bad relay can do it, or a wheel speed sensor can to. Also the relay may be at fault. You can have the codes checked for free at any Auto Zone and they will tell you what part is bad
