Question about Lands Phones
RCA Phone Model 25205 not showing CID info
CID feature on RCA phone Model 25205 not working
  • Anonymous Nov 06, 2008
    Same on mine. Line 1 works (Comcast) line 2 does not show. (Vonage)
How do i turn on the ringer
Posted on May 23, 2008
I have 10 Panasonic KX-T7730 using 8 phone lines. I've confirmed with AT&T that all 8 lines are setup for caller ID. I've confirmed that all 8 extensions have the Caller ID enabled. Two of the
Firstly, you have not indicated which phone system your phones are connected to, e.g. KX-TA824, KX-TDA50 or other, so I'm a little in the dark. That being said, most of the Panasonic Systems only display Caller ID information (CID) to phones that are programmed to "Ring" on the line with the incoming call, and the line button flashes green to show it's ringing... so you must "system program" ringing for the line(s) on each phone. If the CID is not displayed on a particular phone, then that line is likely not programed to ring on that phone (it's light may flash red instead of green). After you "system program" the line to ring, you can still shut off the ringing sound on a phone using the slide switch on the left edge of the phone if you don't want to hear ringing, and this will not interfere with the CID display. Also, on a second note, CID does not display on the first ring coming in from the phone company (TELCO). The CID signal is sent from the TELCO to your system after the first ring has ended, during what would be the silence period that would occur before the second ring, if there was no CID. It is for that reason that most knowledgeable installers program lines with a five second delayed ring; in this way, you don't know the call has arrived until after enough time has passed for your system to receive the CID signal... this is why it seems the CID appears instantly, with an incoming call. Check out the line programming for each line and set it to ring with a 5 second delay. If you don't set up a delay, your phones will ring and if you answer the call immediately, its likely it won't allow the system to receive CID, so no CID will be displayed for that call.
Oct 28, 2014 | Panasonic KX-T7730 Corded Phone
Names of callers do not show on screen when calls come in
does it display other CID info when other people call in? If it does, then someone is blocking their CID from coming through. Hit *77 on your phone and it will block calls from coming in that do not display their info.
If you are not getting any CID info at all, then verify with the phone company that you really do have the service. I paid for the service once and my bill reflected that I had it, but according to them I didn't have it...
thanks.
Apr 27, 2011 | Nokia E5 Cell Phone
M7208 call display not working hot sure how to program it. when calls come in it does not show who is calling
So is the display not working or are you trying to set up caller ID?
M7208 phones were delivered with the very first Nortel systems and if you have one of those, you're not getting CID. The CICS cabinet or higher requries a CID trunk card and IIRC 5.0 or higher software. If all of those are in place, as a minimum you can press FEATURE 811 to display CID info.
Carl
Feb 05, 2011 | Nortel Meridian M7208 Corded Phone
Phone keep initializing
I had the same problem (constant initializing with dropped lines, no dial tone, etc) with my RCA Visys 2-line phone (model 25205) after owning it about 3 months, and could not find a solution on the Web, so I called RCA customer service. They said this problem is not user-fixable and they gave me an RMA# to return it. They will send a replacement phone as soon as you fax the receipt, your name, problem with the phone, etc.. Then when you get the replacement phone you send them the bad phone.
Aug 31, 2010 | RCA ViSYS 2-Line Speakerphone
Answer machine is in spanish
Look for the web address on the machine or on it's container. If found, go to the website and click the english version or locate the icon represention english speaking country to get the version.
Locate the download menu on the site and click manual or any similar info. If it doesn't work, then contact me on abbeyglobeatyahoo.com.
Goods day.
Dec 09, 2008 | Uniden Cordless Phone
RCA 25205 wont answer correctly
Yeah, I've wasted all morning messing with this. My personal outgoing message keeps reverting back to default. I just got off the phone with RCA and here's the fix for that part of the problem. Go into "Configure Out-Going Announcement" (page 23) and then select "personal," This finally made it stay there. The number I called for help is 1-800-511-3180, or 1-866-285-4651. Good luck!
Oct 27, 2008 | RCA 25205RE1 Phone
Can't display caller id info
Does CID work on ANY phone in the system? The reason I ask is because prior to issue 7, a Caller ID card had to be inserted into the trunk card. If yours is older, it may not have the card.
Carl
Aug 26, 2008 | Panasonic KX-T7453 Corded Phone
No CID
This message is in an area that discusses the 25202RE3. If you really have the 202, this model shouldn't have the CallerID capability. If there was ever a model 25204RE3, that model probably has it.
If you bought it brand new, then you might have the space-age chrome/blue-plasma model (2542YRE3?, where Y is either 3, 4, or 5). If Y is 3 (and the model number system holds), you don't have CID/VM. If Y is 4, you do. If Y is 5, you have a built-in answering machine as well.
Jan 15, 2008 | RCA 25202RE3 Corded Phone
Lands Phones Logo
171 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
