Question about Bose Acoustimass 15 System
The bass speaker doesnt work
All speakers are working but the bass speaker is not working.
How should i fix this?
Please let me know
Thanks
Thiru
Cube speakers are working, but base unit is not. Took off the back, fuse okay, need help.
  • 1 more comment
  • triman68 Mar 23, 2008
    Ia m having the same problem with mine and I don't no how to take it apart to check the fuse.
  • chiwiz Mar 30, 2008
    Same thing. Can't get the case open to check fuse. What else could it be besides the fuse? Is there a comparable reliable subwoofer I could get to replace the Bose?
  • musicistabes
    musicistabes Jul 13, 2008
    no bass the bass just stopped working.
OK, Bose owners out there listen up and listen good. Here's the real scoop on 1.(getting access to the inside of most bose subwoofers, 2.( repairing said subwoofer.
Follow these steps in removing the cover of your subwoofer. Unscrew the two screws from the cover. (They are on the input/output side of the cover) Remove the two knobs (Bass and treble volume).
On the opposite side of the cover, (put those damn shoes back in the closet) there is a lockout tab that needs to be swung out, it moves 90 degrees in a counter-clockwise direction and is located under the center of the cover.
A small flat blade screwdriver works great for swinging this tab out and will be necessary for the next step (the screwdriver that is).
On the same side (opposite the input/output side) there are two small tabs near the edges of the cover, one on the right and it's counterpart on the left. If you look closely in the gap between the cover and the sub itself, you will see these 3/8" wide tabs near the edges and towards the top of the cover.
With the flat blade screwdriver, put the blade between the cover and on the tab and pull down. Then with your hand balled into a fist, gently hit that side of the cover towards the input/output side. the cover will move only slightly but the tab should remain depressed.
Do the same procedure on the opposite side of the cover and it will slide about a 1/2 to 3/4" towards the input/output side and can then be removed by pulling it straight up and off of the cabinet.
Yay! If you get this far without incident then you are ready to implement repairs. In the case of the AM15's, normally what happens is a resistor will open up and prevent the triac (turn-on device) from firing.
The fuse is on the underside of the PC board and this above mentioned resistor is a 100 ohm, surface mount "chip" resistor on the top side of the PC board. It will not appear to be bad but trust me, if the fuse is good and the sub will not turn on... replace it!
You don't have to use a chip resistor since as a consumer you may have a rough time finding one but a 1/8 watt or 1/4 watt resistor you can find at any Radio Shack will work just dandy in this application.
Cut the leads short and solder the two cut leads to the pads on the circuit board where the chip resistor is currently sitting. The chip resistor will be black, about 1/4" long, 1/8" wide and have "101" printed on it's surface. On some models they used two 200 ohm resistors in parallel but the result is the same. One 1/4w axial lead resistor will do just fine. Plug it up and give it a try. (Before you replace the cover).
Secondly, if the fuse is blown on a "Lifestyle" Bose subwoofer, contrary to popular belief, it blew for a reason. The speaker outputs and the subwoofer output devices are TDA7294 IC's with TIP142 and TIP147 Motorola transistors used as current supplements to these said output devices. If the fuse is blown and replacing it only results in another blown fuse then chances are good that one or more of these are blown. In some cases it's very easy to tell, the front of these IC's will be blown off and/or you will see burn marks on the board where they are mounted. These devices are located inside the amp portion of the subwoofer. (The black metal heatsink underneath the input/preamp PCB. As a consumer, if the fuse is blown, unless you are familiar with soldering techniques and troubleshooting electronics, leave this to the pro's. It isn't as easy as you might think and you can destroy the PCB in your attempts to repair it.
 This was from a Guru of Bose systems at ecoustics.com: Mark Burgess
Posted on May 11, 2008
  • 45 Answers
If you cant open the bass speaker dont force it open. You will only damage it, and if the housing is damaged then you will have ruined the sound quality. A simple way of checking a speaker to see if it works is.
1. Disconnect all the connections to the speaker.
2. Take a small length of wire, about 2 feet. Connect one end of it to the Bass input of the speaker.
3. Get a "D" size 1.5 volt battery cell. The other side of the wire, dont connect it to the battery but just hold it with your hand to both ends of the battery, for just a couple of seconds at a time.
4. If you hear a humming sound from the speaker, when you have made the connection to the battery then the speaker is good.
You must be having another problem. My suggestion is try another CD from your collection, not a pirated one. If still no positive results then spend some money and get it done through Bose service center.
The bass in my Sony 3-way 6X9 speakers wont work
if these speakers are several years old, chances are that the left one is just blown. could be a loose wire, but if not, it would be cheaper to get new speakers than to get that one fixed
Apr 05, 2012 | Sony 3-WAY 6X9 SPEAKERS Car Speaker
Altec lansing 221 computer speakers sound solution
Unfortunately it looks like Altec Lansing goofed up on this set and didn't provide a bass control knob. You will need to use some sort of software equalizer on your computer to turn the bass down.
Mar 24, 2012 | Altec Lansing 221 Computer Speakers
Buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
G..
Nov 03, 2011 | Logitech Z-4 Computer Speakers
The right speaker not working
Just opened mine just to realize that it only has on speaker on the side. Both sides dont have the bass speakers!
May 22, 2010 | Altec Lansing inMotion iM7 (021986950806)...
Bass Problem
you may have a short in the wiring
you can always open up the bass box and look to see if the wiring is a little loose.
if you know how to use soldering you may be able to fix it.
if not you may be able to just tape it in place
Apr 29, 2009 | Altec Lansing ADA 885 Computer Speakers
Bass Flow Tube
Carefully pry off the gray metal mesh covering the speaker. Don't pry on the plastic ring - you have to remove the metal mesh from the plastic. Remove the six screws holding the speaker in place, and remove the speaker. Finally, re-glue the tube into the port. Wait for the glue to cure before turning the speakers on again.
Feb 14, 2009 | Logitech X-230 Computer Speakers
Logitech r-20 speakers
Hi again andrew63,
There are two possible methods of adjusting the bass and treble output to your Logitech R20 speakers:
1. Hardware - if you feel like experimenting or working with electronic gadgets, you can connect an external preamp with tone control or graphic equalizer between the PC and the input of the speakers/amp; and/or (probably the easiest)
2. Use a software (to listen to your music files/medium) that has a virtual equalizer such the old MusicMatch Jukebox or as an add-on/plug in.
Btw, thanks for asking me to be a Tech Buddy.
Jan 22, 2008 | Acer AL2016W 20" LCD Monitor
Bose Acoustimass 15 System Logo
2,137 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
