Question about Canon imageRUNNER 400S Copier
Canon ir 330-400 copier
We just got an used canon ir 330-400 copier/printer scanner fax, with network, from another office. All sections are working fine (FAX, copy-printer) except the scanner section is not working, Not even manually, I downloaded some software from Cannon, but the machine is installed to the network switch therefore the software can not find the scanner.
Do i need to attach an usb cable to do the settings? or the scanner section is optional? if so, where I can get the scaner Kit?
I'm the tech guy. so i can follow the instruction.
  • techlv Mar 17, 2008
    this copier has usb, network card and parallel,ports. but the scanner is not working because it lack maybe an additional card or scanner kit, or maybe a software driver (I got it) or config.
    That's was my question, Canon support has this model descontinued. I need answer from a repair guy that knows this model.
    thanks.
I have canon ir 400 machine - how to solve E604 error please guide me
Posted on Sep 05, 2011
It is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Posted on May 19, 2009
Iam thiru.... i have canon ir 330-400 copier, i connect copier with PC through hub network.... most of time - (MS Office) copier print some missing lines, and heading what can i do plz solve this......
Posted on Feb 08, 2010
  • Canon Expert
  • 1,326 Answers
I don't know alot about the connectiveity part of this model, but I do know you don't use a "usb cable" you need a cat 5 or ether net cable or you can use it as a parrellel port. Yoy may have to run the net work set up in the copier and you need the IP address. Good Luck
Posted on Mar 16, 2008
I bought an ir330 machine last year. the machine print out e06021000. what does it mean. do i have to replace any parts. the technician said that i have to replace the digital chip. How much does it cost.
Posted on Feb 15, 2011
  • 3 Answers
E001
Posted on Feb 26, 2010
How to print fromt and back pages side by sided in canon ir 3300
Normally the DOUBLE SIDED printing command in located in the section where you select the paper size, type of paper, etc. It usually is under the TAB labeled PROPERTIES
Dec 10, 2013 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
U051 error can i disable printer and use only scanner and fax canon mx300
Sadly not. The cartridge error will have to be resolved before you can use the scanner/fax. You do not however have to have a full cartridge installed, the printer just needs to be able to recognise the cartridge.
Sep 11, 2012 | Canon MX300 Office All-In-One Printer
How i do scanner in canon ir2022
connect computer to network
install canon color network scangear, select printer ip in this software.
now you need scanning software.
I'm using freekapture.
place document in printer scanner. click scan button on printer.open freekapture and start scanning
Jul 06, 2012 | Canon iR 2022 Printer
How to set ip address in canon ir 2830 i want network scan in this machine and send me complete information about net work scan
I need fax facility of my canon ir2830 network machine. pl let me know how to setup for fax in my canon ir2830
Dec 31, 2010 | Canon imageRUNNER 400S Copier
SETUP OF NETWORK PRINTER IR2016I
Install network scan gear on all PCs and make necessary settings ( IP, discover,... ), it should work as PULL scanner.
May 29, 2010 | Canon iR 2016i Black and White Copier
Canon imageRUNNER 400S Copier Logo
2,493 people viewed this question
old marine
old marine
