I just got my gateway1 computer,,and i noticed that the cord that comes out of the monitor,,,has electrical tape wrapped around it,,,,,is this the way these things are built ,,,,,,,or was this one with a defect ?
    Novelist:
  • 142 Answers
Yes
Posted on Mar 15, 2008
SOURCE:
How much tape should I put around my hockey stick?
If you watch professional hockey, you will notice that they barely use any tape. Generally the wrap just enough tape to fit around the stick once.
Jan 14, 2013 | Hockey
Need to replace the cord
If you feel the need to not part with your beloved fan, but instead fix it the solution is simply.
First make sure the cord is unplugged from the wall, electric shocks are painful, trust me.
Then get a pair of wire strippers, NOT wire cutters. If you don't have the right tools, you can strip the wires with a kitchen knife, but this is not recommended as you risk harming yourself.
If the cord is damaged along it's length, you will need to cut out the section that is damaged. Cut the wires wherever you like, cutting to either side of the damaged section.
Bare about 2 to 3 inches (5 to 7 cm) of wire on the two parts of the cord that are undamaged.
Take the positive wires from the fan side and the positive wires from the wall end and wind them together, like you are closing a twist tie.
Wrap thoroughly with black electrical tape. No wire should be visible and it must be electrical tape, as it will not catch fire.
Repeat with the other wires.
If the wires need to be replaced starting at the fan terminal, open the fan casing (having already unplugged it from the wall) and remove the wires from where they are attahed to the fan casing. Please note which is the + and - end. Cut out the damaged section of cord, bare 2 to 3 inches of cord.
wrap the end of the cord around the terminal in the fan.
and do the same with the negative end.
They should be firmly wrapped, so they will not slip off.
You shouldn't need to pthem in place, but you may if it becomes necessary.
Aug 24, 2011 | Emerson Dryers
My little friend Raphi has this player. There is mostly no power to the player. The light will come on once in a while but it seems related to the AC adapter. What does the metallic collar the cord is...
Your little friend Raphi either needs a new power cord or the power input connection at the back of the player needs re-soldering to the board. Basically, there is a partial break in the electrical supply to the DVD player. If you waggle the cable around a little where it enters the back of the unit, the light will probably go on and off.
It needs a little bit of testing to determine exactly where the break is, but it shouldn't cost too much to fix. Any local TV repair shop or a friend with a bit of electronics knowledge should be able to fix it.
Nov 04, 2010 | Bush DVD2038 DVD Player
Dog chewed wires to the sounsticks. Right through. Is there a way to repair?
Strip the insulation back from each end of the severed wires about 1/4". Twist the copper wires that match each other together and solder with a hobby (30watt) soldering iron. Wrap each wire separately with electrical tape and then to make the job look neat, tightly wrap electrical tape around all the wires in a spiral fashion. This should fix the problem.
Aug 10, 2010 | Harman Kardon SoundSticks II Computer...
Fliter queen repair
I generally don't like answering questions like this cause it could lead to unwanted problems. But I will say that if the individual wires are color-coded (each wire is a different color and can easily be determined which go to which) and you are handy with some electrical tape and know about how to make wires connect, then you may be able to do this yourself.
If you are NOT able to determine which wires go to which wire, I definitely do NOT recommend you trying to this yourself.
If it is obvious to you which wires go to which, splice them to clean edges, connect metal to metal, wrap two connecting wires tightly with electrical tape, then once all wires are wrapped to one another, bunch all together and wrap all with electrical tape. That's it.
It's fairly simple, but again, YOU MUST, I STRESS MUST be able to distinguish which wires match which wires from the detached (thanks to dear sweet puppy) wires. :) Bad puppy!
Hope this helps at least some. A good repair person shouldn't charge that much to do it for you.
Best, Jenn
Jul 07, 2010 | Filter Queen Cheetah II Ash - MU305...
In Mar.89 I bought a VCR Model HS-U50. Works great BUt a tape is now stuck in the cassette loading slot and while the Power button comes on and I try to eject the tape, since it wont come out or eject, the...
I took the cover off and noticed the tape was wrapped all around some wheels and unwrapped the tape from the wheels and got it out. Ate the tape up BUt at least its out. However, I tried a new tape and can now see what the problem may be. It keeps on eating the tapes, they get all scrunched up inside around various wheels and while I can get it out, each tape is mangled and beyond use. So something is causing the VCR to incorrectly wrap the tape around each aligned whlle. Dont know how to fix this , BUT since I wont be able to get parts or help on here to do it by myself, Can you be kind enough to find me a repair service outlet in Ottawa, Ontario, canada.
Dec 26, 2009 | Mitsubishi Televison & Video
My puppy chewed the cord to my dyson, is it easy to fix?
Very easy, if you don't care how pretty it is. All you need is a sharp knife and some electrical tape. Use the knife on each end of the cord to expose 1/2" of copper wiring, twist them together, cover each wire separately with tape, then wrap several turns of tape around the whole thing.
Oct 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Cut extension cord
This happens a lot with circular saws too.
You can strip off the insulation from each side of the cut and connect the wires (be sure to match colors!) and wrap the whole assembly in electrical tape, but you really are best off replacing the cord.
If you do repair it, tie a knot in the cord so there's no stress on your repair job when you tug on the cord.
I just did some reading and found out the name of the knot you want is actually the "Euro death-knot" (best example is in this picture)
Tie it with the cut ends just like the ropes in the picture, then do your splice job on the ends of the wires.
Aug 03, 2009 | Electric Garden
Dog chewed cord on bissell model 6579-2 how do I replace it?
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Jun 16, 2009 | Vacuums
Computers & Internet Logo
21 people viewed this question
Ekse
Alun Cox
