Question about HP Officejet 6310 All-In-One InkJet Printer
Only Prints in Grayscale
Cannot seem to change the setting. All my text comes out in gray.
  • DLewiegal Mar 16, 2008
    Thanks. My printer has set dormant for the year I've had it. The black ink level always shows almost full. I've been travel nursing for a long time. Just got a new desktop & connected the printer. Never thought about it being low on black ink, which makes no sense. Appreciate your help. Rita Diane
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    including on test page?
    Genius:
  • 3,587 Answers
Can you please print a test page, and let me know how that works?
Posted on Mar 16, 2008
Want to print black and white. How?
Setting the font type color in a Microsoft Office Word document to black will ensure that the document prints the text in black. However, if there are images, graphics or photographs within the document, they will more than likely print in color or hued colors similar to black. To ensure that the entire document prints solely in black ink, you must set the color settings on your individual printer to black-and-white
Instructions:
1.Click "File" and then "Print." To open the print dialogue box using keyboard commands, press "CTRL" and "P" simultaneously.
2.Select the printer you are using at the top of the dialogue box under "Printer" and "Name."
3.Click the "Properties" button next to the selected printer. The dialogue box that appears is different for all users, as it depends on the type of printer being used.
4.Click on a tab, button or selection box indicating "Color." Most options include high-quality color, grayscale and black cartridge only. Choosing grayscale will print the document using various shades of gray and other tones such as blue or green that match the actual hues in the document visible on the screen. A photo or picture that may look black or gray could actually have blue undertones. To print purely in black and white with no undertones, you must select either "black cartridge" or "black and white only."
5.Select "OK" to return to the Microsoft Word printer dialogue box. Press the "Print" button to print the black-and-white document.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Computers & Internet
I installed the latest driver, 61.82.61.41 and now whenever a user tries to print in grayscale, it prints black pages with white text
Kindly check the printer settings and preferences. Maybe it was set to grayscale, afterwards, try to do a print alignment and last resort is check toner if it's clean. Try to wipe with paper towel and do the printer test. Hope it may fix your problem :)
Jul 12, 2011 | HP LaserJet 3600n Printer
The printer prints color only.
There is an option to make your prints come out in black and white if you go into the "properties" of the printer. Look for an option that says "grayscale". This will allow your prints to come out in shades of gray (black and white).
Hope this helps. :)
Oct 06, 2010 | HP Office Equipment & Supplies
Is there any way to get my printer to print only black copies without having to buy the new color print cartridge
Go to the printer settings - Preferences- color tab - and select Grayscale in the color selection.
Once this is done, try print a color text and see if it comes in a gray scale. This will work.
To give you a tip on this.... understand that this printer has a black ink cartridge and a tri-color cartridge. When we select grayscale, only black cartridge would be used.
Good Luck.
Mar 15, 2010 | HP PhotoSmart C4180 All-in-One Color...
Hi, I have a Macbook running Tiger 10.4.11. I have yet to figure out a way to print in black and white from safari. HELP!
When you go to print (apple/p) and the dialog box comes up (lists printer, presets, copies, etc)
There should be a gray horizontal line across the middle of this dialog box. Note the drop down box that is on this gray line ... this is an important drop down box. When you select different items in this box, all the options underneath the gray line change.
The selection in this box is probably "Layout" by default. Change it to look at the different options, but as things change below the gray line don't get confused about which is the "main" selector drop down for changing all the options .. it's the one on the gray line ....
I'm using an HP printer, and when I select "Paper Type/Quality" in this drop down, I get an option under the gray line that says "color" -- the options in that box include the option for "Grayscale"
If I were to select Grayscale, then the printer will print only in black and white and shades of gray.
That's the easiest way to do what you want, and it will apply to any program you are printing from, since you are selecting "Grayscale" from the print dialog.
Look through all the different variables in the print dialog to become familiar with them.
If you often use one particular setting and don't want to have to go through the sometimes confusing search through the drop downs, since they change back to their defaults each time you print, then you can set a "Preset" - this will remember your settings and allow you to get to them easily ...
To do this, first select all the options the way you like them, for example you might select Grayscale under the Color option under the Print Quality section. Then, before you actually print anything, go the the top where it says "Presets" and do a "Save As" and choose a Preset name that will be meaningful to you ... like "grayscale" -
Next time you print, keep an eye on the preset - it may NOT go back to the default of "Standard." It may stay on the last-used Preset ... so keep an eye on it before hitting the print button.
Hope this helps!
For help with Public Address system feedback, and great AA speaker tapes and MP3 downloads, my website at rexark.com is a great resource!
Feb 08, 2010 | HP Photosmart C6280 Printer
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
HP Photosmart c4480, prints black where gray shades exist
try cleaning the printhead your printer seem to have an image quality issue
Sep 23, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
Printer prints documents with gray-shaded background
check the mode of printer is i grayscale or in colour mode. bye
Jan 30, 2007 | Dell 922 All-In-One InkJet Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
