Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Both VCR and DVD lights are illuminated but neither works
First my DVD would not eject, so I removed the cover to get it out. Now, both DVD and VCR lights are illuminated when the unit is powered on, but neither will allow me to load a tape or DVD. I unplugged the unit for days and plugged back in - problem persists. Any ideas?
  • 3 more comments
  • Scott Quillen Mar 17, 2008
    not sure what to check or how to check it. My main concern is that both DVD and VHS lights are illuminated, which indicates (to me) that neither is being selected, and neither responds to remote or manual input.
    The problem hasn't been fixed, but I received a message saying "GREAT, Thanks for using our premium assistance plan"!!!!
    If that's all the help I'm gonna get...you can bet you won't get any more of my money...
    Come on guys...for $10, you can do better than that!
    Not fixed...I clicked the "Accept" button before knowing that once I did...my "Premium" service is expired...thanks for nothing!
  • Scott Quillen Mar 18, 2008
    There is NO green light flashing...both the VCR and DVD lights are lit solid...like it's trying to have them both operating at the same time, but there is NO media installed in either, and the unit doesn't respond to any input via remote or front panel. It is a Magnavox MWR20V6 DVD Recorder / VCR Combo
  • Scott Quillen Mar 26, 2008
    Any new ideas???
    Guru:
  • 1,894 Answers
Can you tell me the model number of the dvd player???and also its make?
Posted on Mar 18, 2008
  • dewan nafees ahmed Mar 18, 2008
    it is either jammed or somesort of magnetic thing is keeping it from
    ejecting..
    the green light flashing is meaning that it is trying to open
    but it can't and it keeps try to eject.
  • 796 Answers
Have you checked the spindle motor and are they working fine??
Posted on Mar 17, 2008
  • isaac johny
    isaac johny Mar 17, 2008
    below the place where the dvd rotates is the spindle motor..
    when it doesnt function well the lens thinks that there is a dvd/cd inside
    so there is a conflict between the reader and the tray motor...
    so it wont open
    sorry for the late reply...
SOURCE:
Tape is stuck, can't remove it
I remove a stuck tape from a VCR by taking off the outside cover. (My unit was held together by 5 screws.) This allowed me to access the tape and check where it was locked. I had to loosen a twisted tape from the mechanism and then I could eject it. (Note: I unplugged the deck before removing the cover.)
I hope this helps.
(I've been fortunate; I've only had to do this on VCR units (not VCR/DVD) that were out of warranty. If your MWR20V6 is still in warranty, you may not want to open the case at home.)
Dec 17, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have a samsung DVD-V1000 VCR/DVD combo unit. DVD player works fine. been experiencing gradual decline of the VCR and now it won't play at all. will **** tape into the machine but can't get it out. any...
Always frustrating when a videotape gets stuck in a failing/failed VCR deck. Since all decks use a loading motor and gear system, it would be a simple matter of gaining access to the terminal pins of the loading motor (assuming you can see these from the top of the deck) and applying 9V DC voltage to 'unwind' the loading mechanism - you may get a little bit of tape outside of the cassette, but at least it's ejected. If the DVD deck works as you say, you may be able to continue using this for a while.
If the loading assembly is toward the underside of the main deck, you may need to remove the entire VCR mechanism - then you can apply the 9V to the motor to unwind the gear (it is easier to apply a low voltage to the deck rather than use physical force to unwind gears - as you may damage them) - while leaving the DVD deck in the unit untouched. There should be 2 separate mechanisms in this combo - 1 being for DVD the other being for VCR - as long as you are careful when removing the VCR deck, you should have no problem retrieving your tape (with maybe a little creasing but otherwise undamaged) from it. Be careful when removing the top cover and front panel assembly; you don't want anything broken.
Since VCRs are becoming obsolete these days, it is hardly worth getting this one repaired by any service centre (unless you want to pay a fortune, which is usually more than the retail price of a new combo unit). It's up to you.
NOTE: you cannot operate this unit with the VCR deck disconnected from the motherboard (you will get an annoying error display with the VCR removed). Once you have successfully removed your tape from it, reconnect the VCR mechanism to the board - but do not use it - just use the DVD part if that is still OK. Refit the covers, plug machine into power. Done!
You need a lot of patience to undertake the abovementioned action. Fingers crossed.
Mar 28, 2011 | Samsung DVD-V1000 DVD Player/VCR
VHS tape is stuck in the VCR. Tape will not eject, will not play or foward/rewind. The unit has been working just fine with no problems. The VHS tape has been inserted into the machine to record daily...
assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
Jan 29, 2018 | Toshiba SD-V291 DVD Player/VCR
Cannot eject DVD or turn off machine or anything
hold your power button down for 8 seconds and the machine will power down
Feb 19, 2009 | JVC DR-MV5S DVD Recorder/VCR
DVD will not eject, display shows"read".tried unplugging&stop btn
After removing the cover on the player, I rotated the gears manually watching as the locking arms retracted. Once I heard a click ,the drawer unlocked and I opened it and removed the dvd. I replaced the cover and it's good as new!
Feb 05, 2009 | JVC HR-XVC26 DVD Player/VCR
DVD will not eject from JVC HR-XVC27U
Disconnect the Power Cord. Open the Case and go to the DVD unit. On the right side of the unit you will see an indentation which is the mechanical portion of the DVD Unit.
Push the indentatation in, it is the eject switch. The DVD unit door opens remove the DVD stuck in the unit.
Put cover back on plug the unit in, insert a workable DVD and all should be OK.
The problem was the unit could not read a Defective DVD which I made and the unit was locked in to reading the DVD.
I hope this helps
May 22, 2008 | JVC HR-XVC27U DVD Player/VCR
CST.IN Light
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Jan 19, 2008 | Hitachi DV-PF2U DVD Player/VCR
Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Oct 27, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
DVD won't eject DVD
If you have no indication of power(no lights)you might have to remove the top cover and check the main fuse,it might have opened,sometimes they just blow for no reason but if it is black you have more problems ahead.Make sure the unit is not plug in when you do it.If you have lights(display) and unpluging the unit does not help maybe you should consider buying a new one.
Oct 16, 2006 | JVC HR-XVC25U DVD Player/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
