Desktop icon problem
My desktop icons won't stop flashing on and off
  • Sameer Joshi May 11, 2010
    How does it flash on and off???? A weird prob..
  • 30 Answers
Back up your data and reinstall your operating system.
Posted on Mar 15, 2008
White Balance pre icon won't flash
After selecting "PRE" you are releasing the WB button and then pressing and holding it?
Mar 14, 2013 | Nikon D7000 Digital Camera
Tip
How to Download Files to USB Flash Drive
MS Windows Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. <br />Depending on your computer, there can be USB ports on the back, side or front. The flash drive can also be connected to an external port hub device. Once you connect it, the computer will automatically recognize it as a removal device.<br /> 2.Double-click "My Computer" on the desktop. You should see your USB flash drive's icon listed together with other removal devices on your computer.<br /> 3.Double-click the flash drive's icon to open the flash drive window and <br />reveal the contents saved on it. Locate the file you want to download to the <br />flash drive from its current location on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive.<br /> 5.Close the flash drive when you are done. Click the "Safely Remove Hardware" icon on the system tray. A new window will open. Left-click the flash drive and click "Stop." A message will pop-up indicating that it is safe to remove the device from the computer. Disconnect the USB flash drive from the computer (or external hub).<br /> <br />Mac Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. The computer will automatically recognize the device and display its icon on the desktop.<br /> 2.Double-click the flash drive icon on the desktop to open its window and <br />reveal the contents on it.<br /> 3.Locate the file you want to download to the flash drive from the location <br />where you have it saved on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive. Close the flash drive window when you are done and drag the flash drive icon to the trash can to safely eject it from the computer.
on Feb 01, 2011 | Computers & Internet
Ibook g4 won't open just gets a flashing equation mark and the finder icon
Sorry, either your hard drive cable is loose or your hard drive has died.
Mar 10, 2013 | Computers & Internet
No desktop
ok, i won say i understand what u sed **** if u wana go to an earlier state and when ur pc had a desktop! u will need to back it up from a previous restore point, but the problem that u might not have one, so try this:
start > programes > accesories > system tools > system restore....if its turned on and u have a restore point than do it....if its not and ur are just talkin about desktop icons u can right click any where on the desktope, point to arrange icons by , and click to show desktope icons. :)
Apr 30, 2010 | Compaq Presario 5000 PC Desktop
My flash drive does not work. No flash drive icon
The most likely solution to this problem is to go to the computer manufacturers website and find the drivers for your flash drive and install them.
After this, your flash drive should work fine.
Jan 12, 2010 | eMachines T6534 PC Desktop
My icons on my desktop are gone. How do I restore them or put new ones on Windows 98?
Hi hkotterlei
To create new icons, do this
I stopped using Windows 98 ages ago, So, the following instruction is from memory only.
From the Starts -> Program List
  • Locate the program for which you want an icon
  • Right click on it
  • A pop up menu appears
  • Select Create a desktop icon
A desktop icon will be created and placed on the desktop
You can go to that icon on the desktop and rename it by right clicking and ....
Do the above steps for any other programs for which you want an icon on the desktop.
Hope this will help you.
If it does help, please give a rating.
Have a very good day
luciana44
Nov 15, 2009 | Microsoft Windows 98 for PC
No icon only wallpaper
Right click on the desktop and go to arrange icon by > show desktop icon.
Hope this will fix your issue.
Thanks
Kevin
Oct 14, 2008 | Computers & Internet
Taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
Icons on desktop
The icons that flash are probably shortcuts that start with S. The S key is causing both problems most likely. There are screwed labeled with K or a unique icon. All located on the bottom of chassis below keyboard. Remove them and life up the keyboard. Do this while the power is off. Disconnect the ribbon cable from the keyboard and remove it. Power on the laptop and let it boot. Once its to the desktop you can see your result. Then all you need to do is pop out the S key and spray contact cleaner underneath rubber contact sheet. You may have to remove some screws.
Dec 13, 2007 | Toshiba Satellite 5005-S504 Notebook
Computers & Internet Logo
David Payne
David Payne
